Sunroof Install Question
1987 Sunroof Coupe.
I took the sunroof apart a few months ago...and now can't recall how to put everything back in. I'm trying to figure out where the headliner attachment goes. I'm thinking it goes above the rails...but below this metal rod thingy. Although the rod likes to sit right on the rail. So then I was thinking maybe it goes below the rails. Any input? Pictures? Thanks!
-= Kaliv Farstryder =- '87 Porsche 911 |
Does this help? This is a thread I saved for the day I have to repair my sunroof. Excellent info and pics in here.
Sunroof cable repair and new seals 87 911
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
That's awesome. I was looking for a thread like that...but the search engine never seems to pull up the threads I want.
However, I still don't see where the back of the headliner attachment is suppose to be. Above or below the rail?
/bonk.
Now I'm thinking that perhaps it goes in the rail system. Went to page two on that thread and low and behold...I see a picture with it IN the rail system. Thanks!
Ok, new problem. The sunroof doesn't want to close because it looks like it's not lining up right. Driver's side is more tight than the passenger side. However, I don't see where to make the adjustments. Any suggestions for how to get it to line up correctly?
The way I lined up my sunroof was to unzip the headliner, remove one and loosen the second screw holding in the sunroof transmission, just enough to retract the gear from the cables, then 'square' the sunroof panel in its opening and reinstall the transmission. Now, the cables should be the same length. It may take more than one try.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Sunroof Seal
Is there a major difference between the 1976 sun roof construction and the 1987 that was documented so well here?
Jack |
I fixed mine a few months ago on an 89. If both cables are working, then you might need to check the hardware that attaches to pull the sunroof forward. I lost a few parts and found them in the back of the roof. I ended up having to order a piece used that I couldn't find. Check and see if both sides have the same parts and look the same. If the sunroof closes but fails to align evenly, this is most likely the cuprit.
That flat spring should be on the bottom of that steel rod. I've had my sunroof apart and reassembled more times that I want to count. I've replaced just about everything and it still doesn't work. So, it's closed and will remain that way.
The headliner panel only affixes to the sunroof closest to the windshield and, it rides in the narrow track on the sunfoof aluminum guides.
___________________________________________ 2001 Boxster S, Orient Red Current Vehicle, 1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**, 1971 911T **Sold**, 1968 912 **Sold** |
I hope to get to mine this weekend
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
Goldfinger
1984-Carrera (pewter metallic) |
what does the flat spring do? when I put it under the rod the rear of the sunroof will not kick up even with the roof when it closes.
Under and over?? Just for reference, the flat sping goes on the bottom of the rod and will be between the headliner and the rod.
Fred, I'm having the same problem with my sunroof and I've replaced all the parts
I thought that it was supposed to help pull the rear of the sunroof down when opening, but mine seems to open and shut OK without it. I just got mine back together but haven't snapped up the liner yet.
I could be wrong, but I don't remember the flat spring doing anything. I thought that on the rail system, there is a bump, so when the sunroof slides forward, the back of the sunroof rides the bump up and into place.
No, no bump... I've had mine apart more times than I want to admit. I've changed out every component and it still won't rise at the back of the sunroof. I have it disabled with a roll of electricians tape on both corners under the roof panel to force the sunroof to lay flat with the rest of the roof. (no, you can't see the tape)
there is a "post" that the rail fits over that bumps it up at the end of the closing action. I think that the spring is supposed to assist/help with opening from the closed position. No problems right now in the garage but I can't help but wonder if there could be problems opening it while motoring?
