just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
rear wheel size for an RS conversion
I am in the planning stages of an RS conversion and am wondering what is a good size for the rear wheels.
will 16x7's fill the fenders after they are flared? or should I look at 16x8's?
Old 01-09-2005, 06:56 PM
CHILI's Avatar
16X8 will be best. But, a true conversion would be 15X8. 16" wheels came out later. But, they look better and have more tire choices.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-09-2005, 07:00 PM
RallyJon's Avatar
I think you'll need 8s to fill the fenders without spacers. Here are 15x8s with two tires:
993 · 911 · STI · S4 · rally car
Old 01-09-2005, 07:06 PM
Somewhere in the Midwest
MotoSook's Avatar
Unless you are stuck on an original look, you can get up to 10X18's in the back. I plan to use 10X16's with 5.75" back spacing.
Old 01-09-2005, 07:08 PM
just me
paulgtr's Avatar
not so much stuck on the original look, but i just don't want to put huge tyres on the back. what about the front? if I use the 16x7's on the front and find a pair of 16x8's for the rear, what is a good combination of tyre sizes?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-09-2005, 07:12 PM
Todd Simpson's Avatar
Lots more info in the archives, along with pics.
You can run a 16x7 in the rear but it will look a little small. 225/50 will be size tire to run. 16x8 will look great 16x9 a teensy bit better and preferred tire is a 245/45/16 on those sizes. Some put 225/50 on the 16x8.
Up front 16x7's will fit with 205/55's, but can rub in certain cases. Mild rolling and negative camber will make it work. You can even put a 225/50 in the front with a 16x7, but it is a lot of work-heavy fender rolling, stiff suspension and as much negative camber as possible.
951 16x8's will also fit on the front, they are more offset to the inside, 225/50 is your tire choice.
Old 01-10-2005, 10:11 AM
just me
paulgtr's Avatar
thanks for the info
Old 01-10-2005, 10:24 AM
Raynald's Avatar
RS spec.
Hello
if this can help this is the doc. about RS homologation FIA
Ray
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 01-10-2005, 10:40 AM
