Removing interior door handles
I know I've seen some threads on this before but can't seem to locate them. Can anyone point me to instructions for removing the interior door handles in an '87 Carrera (or equivalent)? I'm replacing them with a set from Rennline and I'd like to avoid breaking something if possible
TIA
Old 02-11-2011, 07:47 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It would be probably easier to remove the handle held by 4 5MM Allen Bolts
Just take care not to damage the plastic retaining clips for the latch
'85 Carrera Targa
PCA/POC
Old 02-11-2011, 07:54 PM
cattman's Avatar
As you are replacing them with Rennline units, I assume you mean the pieces that are originally black plastic. Are these, seen here in black aluminum, what you are referring to? If so, let me know and I'll get you the necessary steps...
CATTMAN
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 02-11-2011, 08:41 PM
CATTMAN, yes those are the ones I'm using to replace the original black plastic handles. Thanks in advance for providing instructions!!
Old 02-11-2011, 09:02 PM
Anyone have a pointer to instructions?
Old 02-13-2011, 09:40 AM
cattman's Avatar
Standby Logan, I will take some photos and help you out with directions...
Old 02-13-2011, 11:10 AM
cattman's Avatar
Hey there,
Sorry for the late reply.
Here's how to do it:
1. Remove the door pocket, which is pretty straightforward, and involves removing about 6 screws. This affords you access to the underside of the handle.
2. Pull the handle as you would to open the door, and remove the horizontal rod that pulls the opening mechanism from the back of the handle. It's held in by a small white plastic clip, that I am pointing to here- it should pop out easily. Note that this pic doesn't show that rod, as I took this pic with the door panel off. You may need to pry it up to remove it, which is easily done with needle nose pliers. The handle should now flop around, as it's no longer attached to the door opening mechanism.
3. The handle pivots off of a 1.5 inch vertical rod, which is held in place by a small circlip on both the top and bottom of the rod. Using a pick, remove the circlips- be careful not to lose them, as they may fly off. Then using a pair of needle nose pliers, pull the rod out. Here I am pointing to where the circlips are.
4. At this point, the handle should be off. Getting it back on is the reverse, but the hardest part is getting the rod into the holes of your new metal handles. I found it was a tight fit, and I had to use a mallet to drive the rod through. Then attach the circlips, reattach the rod that activates the door open mechanism, and put your door pocket back on.
Let me know if you need any more details, but that ought to do it!
CATTMAN
Old 02-13-2011, 11:38 AM
nineball's Avatar
one tip - when putting the new handle on attach the circlip to the top of the rod before you install it. this will stop it from sliding down too far and you only have one clip to ruin your day for the reinstall.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-13-2011, 11:47 AM
Cattman, thanks so much for the info!!
Nineball, appreciate the tip.
Old 02-13-2011, 12:31 PM
79 Euro's Avatar
Cattman,
That was excellent. I wish I knew how to "store" helpful post (like this one) that I could easily retrieve in the future. Any ideas?
Andy Kay
Kennedale, TX
817.948.8538
1979 911 SC Euro - Guards Red
Old 02-13-2011, 01:43 PM
cattman's Avatar
Originally Posted by 79 Euro View Post
Cattman,
Thanks, I am glad this was helpful!
In terms of "book-marking" this, you could write to Wayne and suggest he add this to his technical articles section. Or just print it out and keep it in your glove box or garage. Or search for it using words like "door handle", "circlip", "CATTMAN", etc.
Best,
CATTMAN
Old 02-13-2011, 04:46 PM
Or you could actually bookmark it in your brower.
My favorite for threads I know I'm going to want to read again is to subscribe to the thread - which also notifies you when the thread is updated/has new posts.
You don't need to post to the thread to subscribe; go to the top of page, just above the first post select the little triangle on 'Thread Tools' and select 'Subscribe To This Thread' from the drop-down menu that appears.
Then you get to go to your control panel ("User CP" on the menu bar, just above the Thread menus) and create a bunch of folders for various titles/subjects to file your subscribed threads under.
'77 S with '78 930 power and a few other things.
Old 02-13-2011, 06:03 PM
Red Clubbie's Avatar
Guys,
I just went through the procedure of replacing my inner door handles, but the rod that I took off one of the handles end, also came out of the door end......
It looks like it goes through a small hole in the door card but I can't seem to get it attached inside the door.
I didn't really want to take the door card off....
Any help appreciated....
Cheers,
Geoff.
1984 911 Carrera.......
Old 07-15-2011, 11:19 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by Red Clubbie View Post
Guys,
Cheers,
Geoff.
Hi Geoff,
Hope this helps.
Here is a diagram of your door locking mechanism.
Not very difficult, but the door card will have to come off.
You may pm me as needed.
Cheers,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-16-2011, 08:17 AM
Gerry,
Thanks for the diagram.....it looks like No. 18 may have broken inside the door.
I've got spares of these clips, so it's off with the door card then...
I'll let you know how I go.
Cheers,
Geoff.
Old 07-16-2011, 08:57 PM
Removed the door card and this is what I found.....
Looks like the plastic clip is missing, which has caused the metal release rod to come out.
I'll put another clip in and we should be right to go.
Thanks for your help Gerry.
Cheers,
Geoff.
Old 07-16-2011, 11:03 PM
Cheers,
Geoff.
pm me if you need a part #.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-19-2011, 08:56 PM
Gerry,
Thanks for the offer mate, but I had some spare plastic clips...
I put one in today and put all the door back together again and it works perfectly.
Thanks for your help on this.....
Cheers,
Geoff.
Old 07-20-2011, 12:58 AM
Adjust inner door handles
I just picked up a 85 Carrera Coupe, nice car, like it a lot. One thing I really need to adjust is the inner door handles. They stick out somewhat, they don't seem to go back flush with the door. The PO had the original's replaced with aluminum ones.
Any tips on getting them to lay flush?
CB
Gerry,
Cheers,
Geoff.
Old 08-11-2014, 12:50 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
Old thread I know but I’m doing this now and trying to figure out which plastic clips to buy
Can you provide the part #?
Thanks lot
Best,
Gerry
Old 04-11-2019, 12:48 PM
