jtkkz's Avatar
Smile Photoshop help?
Hello
Is there someone out there that can photoshop the porsche side script decal on my car.
I want to see it first before I purchase and place a decal on my car.
Thank You very much
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 01-11-2005, 04:31 PM
I'm not here.
K. Roman's Avatar
I'll do it if you could find the sidescript and post that.
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 01-11-2005, 04:56 PM
jtkkz's Avatar
I am not sure where to find a pic of those decals online.
I will search online for some pics of black side scripts
thanks
Old 01-11-2005, 05:01 PM
<insert witty title here>
Christien's Avatar
Don't have time to do the photoshop right now, but here's a high-contrast image of the decal (taken from a parts website that sells them a while ago, sorry can't remember who/where).
In photoshop you can simply place it in as a new layer, resize it by selecting the area around it and using edit, free transform - you'll also need to rotate it a bit, likely (same, free transform) and maybe taper it (for images where the car is angled) - also using the free transform. You can change the colour too with the colour replacer, or faster with the paintbrush or paintcan filler. Photoshop makes it easy because the decal is a layer in itself.
Hope this helps - I'll do a photoshop later tonight or tomorrow if nobody else does before.
Chris
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 01-11-2005, 05:34 PM
Christien's Avatar
In photoshop you can simply place it in as a new layer, resize it by selecting the area around it and using edit, free transform - you'll also need to rotate it a bit, likely (same, free transform) and maybe taper it (for images where the car is angled) - also using the free transform. You can change the colour too with the colour replacer, or faster with the paintbrush or paintcan filler. Photoshop makes it easy because the decal is a layer in itself. Oh, and use the magic wand tool to select the white background and delete it, so all you're left with is the "carrera".
Chris
Christien's Avatar
Sorry that got posted twice - it was supposed to be edited, not reposted - read the 2nd, not the first.
Old 01-11-2005, 05:36 PM
jtkkz's Avatar
Thank You, but I am looking for the correct year Porsche side script in black
"PORSCHE"
thanks
Old 01-11-2005, 05:37 PM
OZCarrera3's Avatar
I don't have photoshop, but here is the script you are looking for:
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 01-11-2005, 05:56 PM
Christien's Avatar
Crap, sorry for being an idiot. Here's one with the correct script.
Here's the template I used:
Hope this helps.
Chris
Old 01-11-2005, 07:21 PM
911FL's Avatar
Hey Christien, how do you make the layer 'see through' for only the script?
Dan
“Out on some Sonoma County road, with Jimmy Dean and Steve McQueen”
1984 Carrera Targa
Old 01-11-2005, 07:43 PM
jtkkz's Avatar
Thank You
Old 01-11-2005, 08:04 PM
Christien's Avatar
jtkkz:
No problem - anytime. Sorry I don't have time right now to do the other one.
911FL:
When you paste something into a document, it automatically creates a new layer and pastes the clipboard contents into a new layer. The background of this layer is by default transparent. Open the layer window (window menu, layers) and you'll see the small icon of the layers - the new layer has a checkered background - this indicates transparency. If it doesn't have the transparent background by default, (CE (version 7) does by default so I'm assuming other versions will) click where it says the layer name (default is "layer 1") and choose "layer properties" then "none" for color.
From there, I use the magic wand tool to select the white background of the decal image, then just delete what gets selected leaving only the letters.
Does that explain ok? Sorry if that's really verbose, just wanted to make sure I explained as well as possible.
On the same topic, if anyone is good with changing colours of things (like cars) I'd love to know your tricks. I'm appalingly bad at that. (Useful for deciding what colours to paint rooms in the house, too.)
Chris
Old 01-11-2005, 08:22 PM
derek murray's Avatar
i think it would look better without the rocker deco
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 01-11-2005, 08:32 PM
Administrator
Jack Olsen's Avatar
I'm not very good at Photoshop, but this version shows the decal closer to its correct proportions:
Edit: derek murray beat me to it.
Old 01-11-2005, 08:37 PM
Christien's Avatar
Thanks Derek and Jack for the correction - here's another shot at it with better proportions, though I still screwed up the right end where the E overlaps the door seam:
Chris
Old 01-11-2005, 08:49 PM
911FL's Avatar
Thanks Christien! Got it to work just fine.
Dan
1984 Carrera Targa
Old 01-11-2005, 09:18 PM
Nobody
bob tilton's Avatar
i think those would look great on your car john but then again i shouldn't be a surprise.
here's a pic from a car advertised as a low mileage all original 67S on ebay a few years back:
Bob Tilton
www.werkcrew.com
Old 01-11-2005, 09:38 PM
Student of the obvious
LeeH's Avatar
What years was that script used?
Lee
Old 01-11-2005, 10:36 PM
