84 911 carrera transmission & Limited slip
I have a 84 carrera
How can I find out if my transmission has limited slip? My sons tell me I should do a burnout, but I suggested I ask here first.. Thanks Terry |
Juack up the car and put the trans in 5th gear.
Spin one of the wheels - if the other wheel spins in the same direction, you have LSD. If it spins in the opposite direction, it is an open diff. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Ok
Thanks, that sounds easy enough. I guess LSD was an option. Terry |
danged good info, I was near asking the same question about my 84. Thanks guys.
Administrator
5th gear? I may need to visit the gym, but I can't turn the wheels with the car in any gear.
With mine, in neutral, you turn one rear wheel and the other spins in the same direction.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Look at the very bottom of the transaxle case near the drain plug....I believe if there is a -12 (?) between the code stamp numbers ....it's a limited slip....
The sure way is to hand rotate one wheel ( as stated) when in -gear. Same direction movement of the opposite wheel means limited slip. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Re: 84 911 carrera transmission & Limited slip
Matthew “Sometimes the questions are complicated and the answers are simple.” |
look for the "12" between the type# and serial#.
That's funny. Ya they are 16 & 18 and unfortunately (for them good for me) the way I have the car insured, they can't drive it or I'm sure they would let me know..
Thanks John
I will assume that's as Wil said, on the bottom of the tranaxle case near the drain.. |
Will it be listed as an option on the original sticker document?
Going to look now.... Good question... Thanks
The Fox Carrera |
