Richer mixture reduces cylinder head temperature
Does a richer mixture reduces cylinder head temperatures? Especially if timing was retarded to reduce ping.
If so, how rich does it need to be? thanks, anthony |
porsher
A richer mixture will reduce CHT as will eliminating detonation.
Max power is produced at about 13:1 I would say this is the most rich you want to go.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Make Bruins Great Again
Wouldn't it be more accurate to say that a lean mixture will increase temps. You don't want to fix one problem (cyl head temp) by creating another. If the mix is too rich you will have other issues. Make sure your car is properly tuned including plug wires, cap & rotor, filters... and then adjust it to the proper mix. If its still running hot then find the cause rather than make the mix too rich.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
porsher
Unless you are starting at 15:1
Intake temperature is very well kept in check by. Next up would be to control the cylinder head temp. Wondering whether it is worthwhile to richen up the mixture at part throttle/cruise to reduce cht and keep detonation in check. WOT is currently below 12.3. thanks, anthony |
Fuel mix can be adjusted for non-stock applications. Also consider adjusting to a higher octane. What compression P&C's and octane are you running?
Chain fence eating turbo
Richer mixture should reduce temps.
Retarding timing increases temps.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
The car is running great both cruise and WOT. But on long hill climbs at partial throttle (not full/WOT) cylinder head temp can climb. I am thinking of richening the mixture to keep cht in check. Worried that a high cht can lead to detonation and other bad stuff.
I don't have that answer as I am a newbie to Motronic myself (I only have 3 threads asking questions) but that is what I learned from basic engine theory and firsthand experience (on other cars).
The fuel / air ratio for best power is around 1:13 and for best specific fuel consumption (SFC) it is 1:17. Peak EGT occurs at the chemically correct ratio of 1:14.7(02 sensor range) and peak CHT at a slightly richer ratio.
Aircraft Engine Leaning, Mixture, EGT, Fuel Air Ratio, Lean of Peak, Best Power, Ground Procedures, Airplanes - EAI Last edited by stlrj; 08-19-2011 at 03:24 PM.. |
higher power output = higher CHT
higher oil temps = higher CHT detonation = higher CHT high ambient air will increase CHT Many issues cause a higher or lower CHT. A clearer discussion would be related to mix and resulting EGT imho. You can lower CHT when a cylinder is abnormally lean. The EGT will skyrocket but CHT will fall increasing mix lowers EGT and power
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
This is not entirely true. I agree that 12-8-13.6 is the sweet spot for most conditions. So perhaps 13.1 is a good number.
What you are after is a lambda value of 1.0 which indicates a full burning of the fuel. The AFR number associated with a Lambda will change based on what type of fuel you are running. Pure Gas, E10, E15, E20 will all translate into a different AFR. Example, AFR for pure gas is higher than what we mostly buy at the pump which is E10. If you set your fuel for E10 and then run E15, you will be lean because it will have a lower AFR number. If you run gas you will be rich... I think its good to get it in a close range. Taking into account the fuel you are running... not everyone in every condition will just target 13.1. We should all be targeting a Lambda of 1.0. Many software packages will allow you to see the Lambda as either Lambda or AFR. Many will also allow you to adjust the tables automatically based on fuel type and atmospheric pressure...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
