Britain Smith's Avatar
Fuel Pump Mounting Location --> Picture Request
Can someone please post some pictures of the mounting location of the fuel pump when relocating to the front on the car. I am working on getting all of that area back together and I am having some clearance issues with the way that I think it goes, please help me out.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 01-13-2005, 09:55 AM
If you relocate to the front, you can put it anywhere you want that's accessible. I would suggest mounting it outside the trunk at or below tank level. The area around the front suspension crossmember has plenty of room, so I mounted my Airtex FP to it. The pump circular in shape, so I wrapped it in radiator hose (for vibration reduction) and attached it to the CM with large hose clamps. That's one method. There are other ways I'm sure. I also connected a switch in series so I could manually disable the circuit as an added theft deterrant gizmo.
Hope this helps,
Sherwood
http://members.rennlist.org/911pcars
Old 01-13-2005, 10:12 AM
That helps a bit, I am looking for some good pictures of this area...anybody?
-Britain
Old 01-13-2005, 10:15 AM
Somebody has to have a picture of the front suspension components with the fuel pump mounted.
-Britain
Old 01-13-2005, 01:50 PM
101 Projects for Your Porsche 911 by Wayne R Dempsey, p99
available from Pelican Parts.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 02:45 PM
Well, I don't have this book yet...anyone have a picture they can post. Come on guys...
-Britain
Old 01-13-2005, 03:36 PM
lally911's Avatar
Here it is on an 85.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 01-13-2005, 03:53 PM
Ah, thanks.
-Britain
Old 01-13-2005, 03:57 PM
allow me
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 04:03 PM
Thank you very much.
-Britain
Old 01-13-2005, 04:05 PM
there is a bracket, 2 rubber isolator bushings, nuts and bolts, and a strap.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 04:34 PM
lally911's Avatar
Keith Lally
Old 01-13-2005, 04:54 PM
OCD project capitan
BigD9146gt's Avatar
So are both rubber gromets hooked up? The bracket i have has the two like you say, but the bracket holes for the two rubber gromets are at a 10 degree angle difference. Anyone know what i'm talking about?
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 01-13-2005, 05:04 PM
do you mean the rubber is old & cracked and it shifted ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 05:10 PM
