Need Part # For Overboost
Does anyone have a part # for the overboost sensor for a 88 930 and does pelican stock it?
Hi Don. The P/N for the overboost switch is 930 606 101 00. It looks like it's a special order item from Pelican. Wow, and it only costs $8.86. That's cheap for a 930 part!
Here's a link to the Pelican Parts description: Link Regards,
Brian 1981 930 |
Thanks Brian, I guess this is the one that the white wire attaches to and it screws in like a bolt. Don
Yes, that's the one. It's readily accessible once the intercooler is removed. Here's a photo showing its location on the by-pass plenum:
Cheers,
Brian 1981 930 |
You can get an adjustable one from NAPA. I use it on my race car. I will try to dig up the Part number.
Justin |
An $8 part for a 930! tell me another lie. sprbxr, anything adjustible is the last thing i need for this car. I can't even get the fixed things to work. thanks for the replys guys I will order from pelican.. not to keep this thread going or anything but does this part go bad?
Thank you for your time, |
i mentioned in your other thread on the subject that you can ground the white wire temporarily to bypass the switch. if the car doesn't die all the time, then the switch is the problem. this is only a test.
