Jack do you have a link to the kinda roof rack you are using?
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Administrator
I think there's probably a better way to keep the two crossmembers at a fixed distance from each other, but I've never taken the time to do any work on it.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Automotive Monomaniac
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Administrator
Do I have a pic?
Administrator
I split this into its own thread. It originally came from the 'Driver's Ed Equipment List' thread.
Does anyone have a Dakar roof rack kinda system that you could put more than just tyres?
Here is another Thule based solution. I took the idea from Jack and had a friend fab aluminum cross bars that distribute the tire weight across four points and have a vertical piece to keep them in place.
They now (not in this pic) have a set screw on the bottom to keep them from sliding across the 50" load bar and black pipe insulators on the verticals to keep the wheels from being damaged. Tony |
Administrator
Looks like Tony's way would have better aero.
that does look cool
i dont have any pics of the one im thinking of, it was more like a truck offroad rack but I cant seem to find out where i saw it.
disband
i got one on ebay for less than $50 shipped. it took a while to win one but i got over eventually. actually fabbed my own gutter pads, but i found one with 59" bars. i will bump my head getting out of the car im thinking.
never thought of tying them together as was mentioned above. got a project for next weekend.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Irrationally exuberant
I tried carrying my tires the way Jack did and I saw higher oil temps. It was a new motor so I thought it might be the motor. When I saw someone with the same setup on a 3.2 I asked them if they experienced higher oil temps and they said yes. That's just a couple of fuzzy data points but I think that setup may rob some air from the tail area.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Oil temps stayed just under the white line... on my gauge, this should be about 195-200F. It's when the tires are upright that oil temps may become an issue. With the tires on their sides, the air is routed to the tail area. Wind noise and the sensitivity to the wall of wind when passing trucks are my only complaint.
