86 911's Avatar
Send a message via AIM to 86 911
Question Engine or Transmission Trouble? Help
My mom and I went for a a 20 mile drive, and as we were coming home, I revved the car up to 4500 RPM in first gear,pushed it into second, and from 2,000 RPM and up, there is a screeching sound. I cannot tell where it is, but in first, second, and third gear, if I get it past 2,000 RPM, there is that screeching sound. When we got home, I revved the car in nuetral, and there is no screeching at all. Only when the car is in gear. The engine looks fine, but there seems to be a defect in either the engine or transmission somewhere.
Note: The 911 has a 915 transmission and a 1979 3.0 enigne.
Thanks in advance.
edit: I did not feel anything wrong when I drove the car. On the drive, I used a lot of backpressure on the engine when coming down the hills.
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 01-24-2005, 04:02 PM
911mot's Avatar
Hard to say but it could be a loose fan belt or perhaps a worn clutch release bearing?
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 01-24-2005, 04:09 PM
Senior Member
Superman's Avatar
Relax. That noise is almost certainly not anything related to internal engine or tranny parts. Screeching is almost always a drive belt. In this case, it would be either your main fan belt, or your A/C belt. See which one is loosest, tighten it a little and the screech will probably not return. If your A/C was not on during the screeching, then it's probably your main fan belt.
Mocha 1978 911SC. "Coco"
86 911's Avatar
Thanks! That is good to know. I am a bit more relieved. I will check th fan belt. There is no AC in the car either.
Thanks,
Matt
'71 VW Bus
Old 01-24-2005, 04:12 PM
