My mom and I went for a a 20 mile drive, and as we were coming home, I revved the car up to 4500 RPM in first gear,pushed it into second, and from 2,000 RPM and up, there is a screeching sound. I cannot tell where it is, but in first, second, and third gear, if I get it past 2,000 RPM, there is that screeching sound. When we got home, I revved the car in nuetral, and there is no screeching at all. Only when the car is in gear. The engine looks fine, but there seems to be a defect in either the engine or transmission somewhere.
Note: The 911 has a 915 transmission and a 1979 3.0 enigne. Thanks in advance. edit: I did not feel anything wrong when I drove the car. On the drive, I used a lot of backpressure on the engine when coming down the hills.
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver Last edited by 86 911; 01-24-2005 at 03:05 PM.. |
Hard to say but it could be a loose fan belt or perhaps a worn clutch release bearing?
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Senior Member
Relax. That noise is almost certainly not anything related to internal engine or tranny parts. Screeching is almost always a drive belt. In this case, it would be either your main fan belt, or your A/C belt. See which one is loosest, tighten it a little and the screech will probably not return. If your A/C was not on during the screeching, then it's probably your main fan belt.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thanks! That is good to know. I am a bit more relieved. I will check th fan belt. There is no AC in the car either.
Thanks,
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver |
Thread Tools | |
Rate This Thread | |
