Question Idle control valve question
I have always had a fluctuating idle on my 84, so I thought I would troubleshoot it. I pulled the ICV off and everything appears to be loose and operating freely, but the resistance is a little off. I get 30 across the outer terminals and 15 across the center to outer. Bentley says it should be 40 and 20. Is this within tolerance?
Jim B.
'84 911 Targa
'11 F250
'01 Stang GT
Old 01-21-2005, 11:06 AM
Can anyone help me with this.
Thanks.
Jim B.
'84 911 Targa
'11 F250
'01 Stang GT
Old 01-21-2005, 02:59 PM
Two things that make it fluctuate, mixture too rich or base idle speed set too high...take your pick.
-Joe
Old 01-21-2005, 03:07 PM
I doubt if the difference in resistance would make much difference.
There has been quite a bit written on Carrera idle problems. Some people have found setting the bypass to spec helps, other have had to change the mixture adjustment.
Probably the best place to start is setting the bypass adjustment to spec. Do you have Bentley or another manual that give the instructions to do this? If not, try a search on "John Walker" and "idle adjustment" and you should find the instructions.
Tim
1986 911 Cab
2008 Audi A6
Old 01-21-2005, 03:08 PM
kqw kqw is offline
When was the last time the O2 sensor was replaced?
The Fox
Carrera
Old 01-21-2005, 05:16 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
I made my 84 Carerra idle problems go away by doing a couple of simple things.
Check for vacuum leaks (including intakes, use carborator cleaner to spray around lines and intake, not near air cleaner, if idle goes up, you have a leak)
Set idle per factory spec
Have air/fuel mixture set right (need CO2 meter to do right)
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 01-22-2005, 07:50 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
CO adjustment wound up fixing mine, after a full airflow meter refurb and vacuum leak hunt. One note- the airflow meter had developed a "worn spot" on the resistor film that provides the voltage sample to the DME, which cause it to act funny.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-22-2005, 11:12 AM
