Spreadsheet Shift point calculation
I seem to remember seeing a spreadsheet that calculated optimum shift points. You would input your engine performance data and gear ratios, and then the spreadsheet would calculate the optimum shift points. It had a macro or something that did all the calcs. Does anyone know what I'm talking about??
I've done a search and have come up empty.
Thanks.
Matt B
'73 911E
Old 01-22-2005, 08:40 AM
Alter Ego Racing
ErVikingo's Avatar
I have something somewhat similar to what you are asking for but its for 901 boxes. If you give me data on your tire size, torque & HP figures by rpm (every 50 or so RPM increment), final gear ratio and gear ratios, I think I can work it out.
Should be fun ! Let me know
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 01-22-2005, 04:48 PM
bigrubberjeep's Avatar
I think I can help, I have 2 spread sheets, PM me your emial and I will send it.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 01-22-2005, 10:48 PM
Buy them, sell them
Adam's Avatar
I've just made a very easy-to-use one for 915s which is in .XLS format. It not only generates the data, but it also plots a graph showing RPM over Speed.
If somebody can host it, I'd be happy to share it.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 01-22-2005, 11:57 PM
rdane's Avatar
carquip.com under 915 gears for sale
Old 01-23-2005, 12:00 AM
Just to clarify, I'm not looking for a spreadsheet that just shows the speed in gears, but one that allows you to input the hp curve of your engnie and calculate the optimum shift points. I'm sure I've come across it, but I can't seem to find it now.
Matt B
'73 911E
Old 01-24-2005, 11:25 AM
I thaught redline was optimum!
(J/K)
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 01-24-2005, 11:26 AM
Bill Verburg's Avatar
Is this what you are looking for
You will need your gearing and tire size
Bill Verburg
Old 01-24-2005, 11:56 AM
Optimum shift points are (generally) just past the hp peak
Bill Verburg
Old 01-24-2005, 11:57 AM
Nope, not exactly what I'm looking for. It's an Excel spreadsheet.
Regarding optimum shift points, it will be somewhere between HP peak and redline. It varies depending on the HP curve and gear ratios, and the optimum point isn't necessarily the same for each gear.
Matt B
'73 911E
Old 01-24-2005, 02:03 PM
David's Avatar
I found this spreadsheet rather interesting. I haven't taken time to check their math, plus it's protected: http://www.offroadvw.net/exceldyno/
Old 01-24-2005, 04:41 PM
Used Up User
imcarthur's Avatar
That is one cool spreadsheet.
Just have to gather all the data to make it work . . .
Ian
'87 Carrera Cab
Old 01-24-2005, 07:22 PM
I did something similar w/ available thrust at the rear wheel vs rpm or speed. You do need dyno #s as well as the gearing and tire #s
If you have the time to look for the mathematicly precise point your not paying attention to more important information.
Bill Verburg
Old 01-24-2005, 07:34 PM
304065's Avatar
The ideal shift point? Just after you've pulled in front of the guy you're passing and before the rev limiter kicks in.
Bill, that's an interesting graph, can you tell us more about it?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-25-2005, 06:51 AM
Sounds like something that would be easy to code in a perl cgi script
Old 01-25-2005, 08:02 AM
