-   -   * Interesting 3.6 engine build coming up * (http://forums.pelicanparts.com/porsche-911-technical-forum/202803-interesting-3-6-engine-build-coming-up.html)
silverc4s 03-08-2005 11:07 AM
That was jpnovak; he's still at it - saw more parts the other day...;-)
Craig 930 RS 04-05-2005 10:50 AM
Clewitt pulley installed:
http://forums.pelicanparts.com/uploa...1112726875.jpg
http://forums.pelicanparts.com/uploa...1112726906.jpg
Some trick goods in here:
http://forums.pelicanparts.com/uploa...1112726934.jpg
Completely installed:
http://forums.pelicanparts.com/uploa...1112726958.jpg
About 294 HP with about 10 miles on complete rebuild.
Tune and break-in will probably yield about 310+ RWHP
911teo 04-05-2005 10:58 AM
http://www.pelicanparts.com/support/smileys/clap.gif http://www.pelicanparts.com/support/smileys/clap.gif Now we need driving impressions!
Craig 930 RS 04-05-2005 10:59 AM
OOooohOOhhhhh......you should hear it idle.
POP POP POP POP....high compression goodness. Race gas.
don911 04-05-2005 10:59 AM
I think I know that car. If so, it was fast enough. It always blew by me like I was standing still when it had a mostly stock engine. I hope he's giving rides when it's done. I'll bring a some extra tidy whities.
Craig 930 RS 04-05-2005 11:01 AM
Its the car you think, Don.
He wants it under wraps for a bit, though --
silverc4s 04-05-2005 02:21 PM
pop the deck lid, check oil, adjust shocks...I like it a LOT!!!
Bill Verburg 04-05-2005 02:47 PM
Did he set up the Motec w/ the stock induction? Seems like a real waste. What cams did he end up w/?
Craig 930 RS 04-05-2005 03:00 PM
Yep. Not sure on the cams, fairly wild.
Walko 04-05-2005 03:26 PM
I would like to see the dyno sheets when it is done
Sweet motor
Michael
Craig 930 RS 04-05-2005 04:09 PM
Had a really funky, wavy/jagged power curve up top - some serious tuning req'd
randywebb 04-05-2005 05:11 PM
The Motec point is a good one... maybe the motor is set to be "expanded" in stages? Or is the tunng ability of the Motec unit worth the extra labor with some other system?
Craig 930 RS 04-11-2005 11:17 AM
Well, it is finished.
It made its 'public debut' at the PCA track day this past Sunday. Hellaciously quick. 2690 lbs. I believe there are about 5-7 more hp when fully broken in.
The chart of my 3.6 Varioram is right below Ted's to use for comparison
Ted Anthony 3.8 with MOTEC and 100% 110 octane race gas. I had Ted switch from a B&B muffler to a Magnaflow we had sitting around. Instant 11 hp. Same dyno, same conditions, same tuning.
http://forums.pelicanparts.com/uploa...1113246656.jpg
Craig911 Varioram - 92 pump unleaded with 3.8 cams
http://forums.pelicanparts.com/uploa...1113246830.jpg
The car:
http://forums.pelicanparts.com/uploa...1113246937.jpg
http://forums.pelicanparts.com/uploa...1113246959.jpg
911teo 04-11-2005 11:24 AM
So 10% increas on max power, 5% increase on max torque...
Craig I think you should be pretty happy with your engine... The torque you are putting out is incredible... even when compared to the best!
Craig 930 RS 04-11-2005 11:45 AM
I wish it were mine!
It is a friends' - Ted Anthony's
I've got the Varioram slug (which BTW has the same power to weight ratio as Ted's car - 2405 lbs vs 2690)
911teo 04-11-2005 11:49 AM
That's what I meant... "only" 5% increase in torque with MOTEC and 110 octane gas between your slug and Ted's beast. I bet there is more than $10k diff between the 2...
Craig 930 RS 04-11-2005 11:59 AM
.......my thinking exactly
rdane 04-11-2005 12:04 PM
So ya think 2150# and 280 rwhp (new muffler pulled another 10+ as well) will hang in there with your cars ;) Depends on who puts enough rubber down I would think. Jason running the most? Never seen his numbers or weight.
2690# and 305 hp = 8.819T
2405# and 277 hp = 8.682C
2105# and 268 hp = 7.854A
2150# and 280 hp = 7.678D
2650# and 430 hp = 6.162L :eek:
Craig 930 RS 04-11-2005 01:34 PM
Do you have 2150 as a solid & final weight for your car?
I hope she doesn't rattle and reverb as much as another stripped early car I know of...... or those road trips will be hell......will make the 'wind noise' trivial ;)
But yes, it will be an acceleration BEAST.
As always.......its is all about Power to Weight!
Have the dyno chart for us to see?
I'm telling ya.....you will LOVE it.
But you have already experienced a 3.6:cool:
rdane 04-11-2005 02:02 PM
All in due time my friend...
Still doing some engine tweaking and the new car has yet to be on the local scales for the official weigh in. I'm doing several exhaust configurations on the dyno to see what we come up with for final #s.
No worries on rattles and wind noise as it will be much better than before. Which was better than a new 'SC. Gotta remember I intentionally built a street car.
To be honest a 3.6 is nice but not all that impressive for my own use.
The reason I changed engines was the improvements in engine management and engineering, not power. The 3.4 CIS was fine.
Mid '70s Porsche technology though verses '95 Porsche technology leaves little choice. When it comes with another bump in power who's to argue?
