-   -   * Interesting 3.6 engine build coming up * (http://forums.pelicanparts.com/porsche-911-technical-forum/202803-interesting-3-6-engine-build-coming-up.html)
Craig 930 RS 01-22-2005 03:22 PM
1991 3.6:
MAF
3.8 P&C
The pistons are very unusual; not the usual 3.8 pistons. These are almost 12:1 Mahles, special ordered.
Wildest cam grind I've ever seen installed in a 3.6. More info coming -
Chip burned for race gas only
Since I had 280 RWHP - my guess is that from the compression increase, cams, and displacement increase that it will approach if not slightly exceed 300 RWHP.
Stay tuned,
Carrera3.5L 01-22-2005 03:35 PM
I've got my popcorn sitting right here next to the computer. This should be interesting...
Ralph
Lukesportsman 01-22-2005 04:58 PM
Consider this thread subscribed
austin552 01-22-2005 07:47 PM
Front and center....
Show time?
Shuie 01-22-2005 08:08 PM
Pray tell
911teo 01-24-2005 07:31 AM
I would guess even higher than 300 rwhp. On displacement only you should get 295. Plys higher CR plus wilder cams. And since you say the chip is custom programmed for racing I guess the peak power will be somewhere around 325 rwhp.
Keep us posted
Wrecked944 01-24-2005 07:54 AM
What kind of intake manifold are you going to use? Stock varioram? Individual throttle bodies?
Craig 930 RS 01-24-2005 08:01 AM
Matteo -
I do think it will be higher than 300 RWHP on this dyno many of us in the Seattle area use. I'd gues 303. Stay tuned - I have some pics coming up. The pistons are a sight to see.
Stock plastic 964 manifold
911teo 01-24-2005 08:07 AM
Is that for the law of diminishing returns? 3.6 to 3.8 = 105%...
280 x 105% = 294.
Plus increase in CR, plus wilder cams, plus racing chip.. Yeah maybe 325 rwhp is silly, but I would have thought a little more than 300... Either way it's going to fly.
Joeaksa 01-24-2005 09:19 AM
Bill Verburg had a special 3.6 upgrade built for him last year. Do not believe that it was as "warmed over" as yours sounds like it will be but it was far from stock either.
Hope he chimes in here, sounds like a interesting engine!
JoeA
3.6 911 01-24-2005 10:22 AM
you might want to check this out:
http://www.instant-g.com/Products/36Conversion/38.html
my engine was the last one described.
Bill Verburg 01-24-2005 12:24 PM
Hi Bill! How's it running?
and mine was #5
please take all these #s w/ a grain of salt, a factory sprint 3.8RSR was rated ~380
silverc4s 01-24-2005 01:09 PM
Count me in at >320 rwhp ;)
Craig 930 RS 01-24-2005 02:28 PM
Here are the pistons:
http://forums.pelicanparts.com/uploa...1106605450.jpg
http://forums.pelicanparts.com/uploa...1106605492.jpg
http://forums.pelicanparts.com/uploa...1106605543.jpg
silverc4s 01-24-2005 02:34 PM
Craig,
It looks as though these pistons are coated. Is that Teflon? or can you tell us more about that.
Thanks.
Craig 930 RS 01-24-2005 02:35 PM
The skirts do appear to have a coating - but I'll be damned if I know what it is.
david914 01-24-2005 02:41 PM
http://forums.pelicanparts.com/uploa...1106606462.gif
Craig 930 RS 01-24-2005 02:46 PM
Going in this tired 66k 3.6 engine:
http://forums.pelicanparts.com/uploa...1106606433.jpg
Bill Verburg 01-24-2005 03:04 PM
Those look like my pistons, if so they are 102mm, 12:1 Mahles, the coating is 3 - 4 <FONT FACE="SYMBOL">m</FONT>m Grafel coating
You didn't show the trickest part which is the tapered wrist pins
993RSR mahle on the left, 2.7RS(JE) on the right
http://forums.pelicanparts.com/uploa...1106607799.jpg
Craig 930 RS 01-24-2005 03:06 PM
Yes, 12:1 pistons Bill. The wrist pins are indeed tapered - think megaphones on each end - big end outwards.
