yogi's Avatar
clunking sound at autocross
Here is the situation. I've gotten a rear clunking sound during some hard turns at the autocross events. It only happens sometimes and sounds like it might be from the passenger side, but I'm not completely sure. I just had bilstien H/D shocks put on the car. The rear sway bar mounts look good. One has been updated to the butterfly brace and the other is stock. It shows no sign of cracks. The sway bar bushings also look good. With the new shocks at yesterdays event I am still getting that clunking sound sometimes. Does anyone have any sugestions at what to look for? thanks
Jerry Baer
87 Carrera Coupe
Old 01-24-2005, 06:02 AM
Friend of Warren
CV joint going bad.
Kurt V
Old 01-24-2005, 06:14 AM
yogi's Avatar
Kurt, thanks for the suggestion. I did look thru my service records. The P.O. had the rear axle assembly replaced 10k miles ago. The clunk only happens during hard turning when pushing the car. It has never happened during street driving. It is definitely a clunk and not a click.
Jerry Baer
87 Carrera Coupe
Old 01-24-2005, 06:29 AM
Plavan's Avatar
It could be a bad bushing on your sway bar. Just double check everything.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 01-24-2005, 07:34 AM
Elombard's Avatar
eye ball your alignment. I had an adjustment come loose. It was not easy to tell, only moved under heavy loading. try putting a wrench on the camber and tow adjustment. I also had a clunk when one of my lower schock bolts backed out a little (I had forgoten to tighten it- dooh.)
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-24-2005, 08:20 AM
banjomike's Avatar
I bet one of the swaybar mounts has broken. Happened to me at autocrosses, 2 times. Once for each side.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 01-25-2005, 12:21 PM
Banned
Loose shock,cheers,Antonio.
Old 01-25-2005, 12:39 PM
yogi's Avatar
Thanks for the sugestions, all of them will be looked into until I find the cause.
Jerry Baer
87 Carrera Coupe
Old 01-25-2005, 03:02 PM
