greglepore's Avatar
Lazy Man's suspension work
Front suspension question-I'm doing tbars and upgrading to a 22mm sway; figure maybe I should do A arm bushings as well. If I'm not changing out tie rods or ball joints, can I simply remove the ball joint wedge bolt and unbolt arm mounts and tbar brackets and drop both arms and sway as a unit? Any problems getting everything reinstalled if I do this? Looks like it should work, but thought I'd ask first.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 01-24-2005, 11:07 AM
I would rather be driving
jpnovak's Avatar
Yes, that works. don't forget to unbolt the steering rack from the cross member. the other option is to remove the cross member bolt off one side and pull the a-arm out.
Chuck's Elephant Racing bushings are nice.
Old 01-24-2005, 11:16 AM
