Spreadsheet Shift point calculation
I seem to remember seeing a spreadsheet that calculated optimum shift points. You would input your engine performance data and gear ratios, and then the spreadsheet would calculate the optimum shift points. It had a macro or something that did all the calcs. Does anyone know what I'm talking about??
I've done a search and have come up empty. Thanks.
Matt B '73 911E |
Alter Ego Racing
I have something somewhat similar to what you are asking for but its for 901 boxes. If you give me data on your tire size, torque & HP figures by rpm (every 50 or so RPM increment), final gear ratio and gear ratios, I think I can work it out.
Should be fun ! Let me know
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
I think I can help, I have 2 spread sheets, PM me your emial and I will send it.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Buy them, sell them
I've just made a very easy-to-use one for 915s which is in .XLS format. It not only generates the data, but it also plots a graph showing RPM over Speed.
If somebody can host it, I'd be happy to share it.
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
carquip.com under 915 gears for sale
Just to clarify, I'm not looking for a spreadsheet that just shows the speed in gears, but one that allows you to input the hp curve of your engnie and calculate the optimum shift points. I'm sure I've come across it, but I can't seem to find it now.
Matt B '73 911E |
(J/K)
Optimum shift points are (generally) just past the hp peak
Nope, not exactly what I'm looking for. It's an Excel spreadsheet.
Regarding optimum shift points, it will be somewhere between HP peak and redline. It varies depending on the HP curve and gear ratios, and the optimum point isn't necessarily the same for each gear.
Matt B '73 911E |
I found this spreadsheet rather interesting. I haven't taken time to check their math, plus it's protected: http://www.offroadvw.net/exceldyno/
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Used Up User
That is one cool spreadsheet. Just have to gather all the data to make it work . . . Thanks Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I did something similar w/ available thrust at the rear wheel vs rpm or speed. You do need dyno #s as well as the gearing and tire #s
The ideal shift point? Just after you've pulled in front of the guy you're passing and before the rev limiter kicks in.
Bill, that's an interesting graph, can you tell us more about it?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Sounds like something that would be easy to code in a perl cgi script
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
