Valve guides replacement
Hi folks,
My 87 Carrera is burning quite abit of oil but my plugs are clean. So I guess my valve guides need replacing pronto.
Appreciate if anyone can help me with a list of items I would need as part of the valve guides replacement job.
My guess would be:
1. Valve guides
2. Cam cover gaskets
3. maybe exhaust valves?
4. ??
Thks!
Old 02-03-2005, 07:49 AM
the intake valve stems are usually quite worn, if you take a mic to them. intake, exhaust gaskets, valve cover kit, tuneup parts, oil, filters, cam lines maybe, check the clutch, for a few things.
206 637 4071
Old 02-03-2005, 08:00 AM
Hendog's Avatar
Are you new to the 911? I am, and what I thought was a lot of oil being burnt was actually normal oil consumption. Could that be the case?
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 02-03-2005, 02:06 PM
How much oil do you use per ??? miles.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 02-03-2005, 02:19 PM
Hendog's Avatar
I've used about 1.5 litres in about 8000 Km (5000 miles).
Henri
Old 02-03-2005, 02:21 PM
when it gets to a quart in 300-500 miles, it's probably time. a crusty oil fouled plug in one hole gives you a clue too.
206 637 4071
Old 02-03-2005, 02:57 PM
