993 retrofit
I posted a request last week asking if anyone could tell me if 993 composite valve covers work on an earlier (930) motor. My engine is twin plugged and I also need to know if the holes align for the second plugs. My understanding is yes to both. If any one could confirm they'll work I'd appreciate it. By the way I would also like to buy a nice set of 993 covers if ithey work. Thanks
Old 01-28-2005, 07:20 AM
Az911's Avatar
Send a message via AIM to Az911
I don't have an answer to your question just some advice.
A more descriptive thread title would help in getting an answer i.e. Do 993 valve covers fit a 930
72T RS look
96 993
Old 01-28-2005, 09:43 AM
Steve, I tried that last time and had over 100 views, but no reponses. Perhaps nobody knows and I've stumped this vast pool of Porsche knowledge. I guess I'll just buy a set and roll the dice. Thanks for the advice though.
Old 01-28-2005, 01:50 PM
Senior Member
Natchamp's Avatar
As far as I know, there are 3 seperate valve covers (that are not interchangable); early 911, 964, and 993. I bet the twin plug wouldn't be an issue but the basic valve covers between those 3 categories are not interchangable. How do I know? because I'm doing research right now to consider making billet valve covers.
Mark
The Beast
mark@hargett.com
www.HargettPrecision.com
Old 01-28-2005, 05:38 PM
Irrationally exuberant
ChrisBennet's Avatar
I've fooled around with this and will try it again. The most obvious difference it that pre 964 valve cover studs are 8mm and the 964/993 covers use 6mm. There may also be some issues with clearing the cam housing oil line fittings.
Here's some more links:
Adapting 964 Valve Covers on 911/930 Engines
cam housing part number question
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-28-2005, 06:00 PM
Thanks for the info guys. I think I'll get hold of a set and see what the deal is and post a clear answer. I'm doing this all for weight saving reasons, so perhaps its a moot point.
Old 01-28-2005, 08:20 PM
scca_ita's Avatar
The 993 covers also have an extra stud on the out side. I discovered this when I wnt to 964 cam towers and wanted to use the 993 covers. I opted to use the 964 covers because the 993 covers would have had one less stud to seal them down. So I think the answer is no.
Old 01-28-2005, 10:23 PM
