on-ramp's Avatar
1970T 911 Doesn't start after battery re-charge.
All the lights are on, seems like i have power, but the engine doesn't want to turn over. ie. starter is stuck.
I also hear a loud whining sound from the fuel pump (?).
Car's been sitting for a couple months, started just fine before. Car is very original. any thoughts? thanks.
Old 01-30-2005, 10:09 AM
limble's Avatar
Have you tried the screw driver on the solenoid trick? Not the safest thing to do but might tell you if it's either the starter or the solenoid. Oh yeah it will toast the tip of your screwdriver.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 01-30-2005, 03:37 PM
on-ramp's Avatar
i can't get a good ground from the charger clamp to recharge the battery. the body is no good because of paint everywhere.
Any other ideas for a good ground? thanks.
Old 01-31-2005, 05:42 PM
Early_S_Man's Avatar
Porsche Crest
Take the battery loose from the car's electrical system before charging!
That will give you a chance to clean the battery terminals and cable connectors ...
The CDI unit can be damaged by BATTERY CHARGERS! ... per Bosch documents!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-31-2005, 05:51 PM
limble's Avatar
The whining or some call it a whistling sound might be the CDI unit. it should sound like that. Got a dremmel? Clean the connections. The engine should be grounded to the car frame, that connection might also be corroded.
Thanks,
Mike
Old 01-31-2005, 07:14 PM
