Question Identify this Engine please
I purchased '70 911 with what I was told is a rebuild 3.0L SC motor from a different car. It has updated tensioners, carrera valve covers and supposedly higher compresson 10:1 pistons.
But I'm a little confused as to the serial numbers on this engine. It doesn't match my other SC engine.
The vertical number on the side of the fan is:
*67C0298*
The horizontal number is:
930/60
I have this engine up for sale. But if it turns out to be something special I may just rebuild it. Low compression in cylinder 2.
Can anyone enlighten me?
Old 04-03-2005, 01:34 PM
Grady Clay's Avatar
A 930/60 is a RoW 3.3 Turbo, 97 x 74.4 = 3299 cc.
I think the "C" may be a zero.
If so;
670xxxx
6 = Six cylinders.
7 = Turbo 3.3 RoW/Japan.
0 = 1980
xxxx = Consecutive serial number.
If so, that would make it an '80.
If it has the 74.4 mm stroke crank, you could add some 100 mm P&Cs and have a high compression 3.5. Worth looking into.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-03-2005, 01:41 PM
charlesbahn's Avatar
According to the Red book it is 1981 turbo engine for RoW/Canada.
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 04-03-2005, 01:44 PM
I have made sure. There is definitely a "C" in the number not a zero.
*67C0298*
But the engine is an NA. Did someone build a NA engine out a turbo case?
Old 04-03-2005, 02:25 PM
Grady Clay's Avatar
I went here;
http://www.adelgigs.com/911scproductiondata.shtml
And the “C” appears to indicate a 1982 model year engine.
That now leans toward an ’82 3.3 Turbo 930/60.
Yes, you can build a NA engine on that base.
Best,
Grady
Old 04-03-2005, 02:57 PM
Thanks guys,
looks like its a 930 turbo motor from a 82.
Here is a link I found with all model year codes:
http://home.arcor.de/s-g-e/911dat.htm
I don't want to open up the case to see what's in it until I'm sure if I want to rebuilt it. But it has been converted to NA.
My next question would be what would this motor be worth after a rebuild or in its present condition?
Currently cylinder two is dead. I may pull the head and check to see if it's a valve. All other cylinders have good conpression.
Old 04-03-2005, 03:38 PM
Grady Clay's Avatar
I would recommend an additional cylinder leak test. That will give you an indication of where a problem is. You can do this even if the engine is out of the car.
Best,
Grady
Old 04-03-2005, 03:48 PM
I have decided to go ahead with the sale. The engine is in the classified section.
Engine for Sale AD
thanks
Old 04-03-2005, 07:03 PM
