Hendog's Avatar
Windshield washer questions
My drivers' side washer jet wasn't working at all until I poked a wire down the jet holes. Now it squirts a little. The passenger side squirts like it could drill a hole in the windshield! has anyone removed and cleaned out a jet to restore its' performance? This is the heated type on my '87 Carrera. If my trouble is compounded by a poorly functioning T-connector and I were to change it out, do I replace the crimp rings with hose clamps or are crimpers and rings available somewhere?
Attached is a pic of the T-connector with crimped rings.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 01-31-2005, 11:30 AM
Glasgow 911SC's Avatar
I'll bump this one up.
After a recent cold spell my jets stopped squirting The passenger side now works but there's nowt from the drivers side. All the hoses look to be in place.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 01-31-2005, 11:35 AM
Hendog's Avatar
Thanks Chris. This has been inoperative since I purchased it 10 mos ago. It isn't cold related unless the cold weather in the past caused some break down in the jet.
Henri
Old 01-31-2005, 02:18 PM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest T-piece
Hi Hendog,
The T-piece you're reffering to is actually a valve. This is the most probable cause of your problem. Partnumber is 91462843300. The crimped rings are still available but you can also use little hose clamps.
Kees.
Old 02-01-2005, 11:50 PM
Used Up User
imcarthur's Avatar
As kees said. The L & T valves clog & no, you can't just blow them out to clean. Replacements are cheap. Go to Home Depot etc for hose clamps - plumbing dept. Or you could also use tiewraps in a pinch. Tighten with pliers to clamp.
Ian
'87 Carrera Cab
Old 02-02-2005, 06:45 AM
