Windshield washer questions
My drivers' side washer jet wasn't working at all until I poked a wire down the jet holes. Now it squirts a little. The passenger side squirts like it could drill a hole in the windshield!
has anyone removed and cleaned out a jet to restore its' performance? This is the heated type on my '87 Carrera. If my trouble is compounded by a poorly functioning T-connector and I were to change it out, do I replace the crimp rings with hose clamps or are crimpers and rings available somewhere? Attached is a pic of the T-connector with crimped rings.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
I'll bump this one up.
After a recent cold spell my jets stopped squirting The passenger side now works but there's nowt from the drivers side. All the hoses look to be in place.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Thanks Chris. This has been inoperative since I purchased it 10 mos ago. It isn't cold related unless the cold weather in the past caused some break down in the jet.
911 carrera 3.2 (1985)
Hi Hendog,
The T-piece you're reffering to is actually a valve. This is the most probable cause of your problem. Partnumber is 91462843300. The crimped rings are still available but you can also use little hose clamps. Kees. |
Used Up User
As kees said. The L & T valves clog & no, you can't just blow them out to clean. Replacements are cheap. Go to Home Depot etc for hose clamps - plumbing dept. Or you could also use tiewraps in a pinch. Tighten with pliers to clamp.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
