Jcon's Avatar
Why did Turbos get smaller rear sways
Porsche used 20mm rear sways on 86-89 Turbos, but 21mm rears on 86-89 carreras. Any reason why?
Jeff
Jeff C
76 912E 2.6L
Old 02-05-2005, 05:27 AM
Bill Verburg's Avatar
The wanted to reduce oversteer or put another way increase understeer.
Bill Verburg
Old 02-05-2005, 05:44 AM
Jcon's Avatar
Sounds reasonable...so a better match for my 81 SC / 3.6 would be the 22/21 combo from the carerra rather than the 22/20 from the turbo?
Jeff
Jeff C
76 912E 2.6L
Old 02-05-2005, 06:30 AM
Send a message via Yahoo to Lukesportsman
I'm going along with Bill, but adding reputation on the street. 911's had bad rap about going off the road backwards and the turbos were known to be off/on switches. I'm not necessarily supporting either of these urban myths, but they existed. Look at Detroit, understeer might be slower but safer for the unaware/unexpecting driver. Snap oversteer on the street with little tires and wet dirty roads is a marketing nightmare. Racer's could/will improve the balance anyway.
Was there ever a class to race a "stock" 930 competitively? I can't think of a class that would allow this monster in as a pure showroom competitor.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-05-2005, 07:51 AM
Dunno, it depends on so many other things, not the leasty of which is driver preference.
I like adjustable bars, if you suddenly don't like something it's easy to try something else.
Bill Verburg
Old 02-05-2005, 08:46 AM
Tell us how the smaller sway bars increases understeer. Is it because with the softer rear suspension the rear end squats on accellerating thus increased traction in the rear causing the front to plow?
1980 911SC Targa 3.6L
Old 02-05-2005, 09:27 AM
Diss Member
Quicksilver's Avatar
Acceleration increases understeer by planting the rear tires as you have mentioned. Sway bars (anti-roll bars) do nothing on acceleration and deacceleration. They only act when the car is leaning to the side. Basically when the loaded side compresses it tries to limit the droop of the unloaded side.
The reason the smaller rear bar will increase understeer is it allows the rear wheels to be a bit more equally loaded so that end does more work. The front sway bar ends up doing more of the roll limiting and the tendancy towards more unequal loading between the 2 front tires will limit its grip.
Wayne
Old 02-05-2005, 11:08 AM
PMB Performance
Eric_Shea's Avatar
I'm using 1976 Turbo bars on my RS clone, front and rear. For this lighter tub they seem to be fine.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-05-2005, 11:12 AM
Jeff Alton's Avatar
The relative stiffnes of the suspension on each end of the vehicle has an impact on oversteer/understeer. A softer front end/stiffer rear will give more oversteer. A stiffer front end/softer rear end will give more understeer. Swaybars are just one factor in the stiffness eqaution. Don't forget the Turbo had larger rear torsion bars to go with that slightly smaller rear sway bar.
Jeff
www.turn3autosport.com
Old 02-05-2005, 01:27 PM
Turbo had larger rear torsion bars...yes indeed... ( by itself causing less understeer) as well as a wider rear track (....by itself increasing understeer).
Let's now add that the Turbo also has a wider front track ( by itself causing less understeer)....and you'll conclude.....
...There were a number of pro-con changes compared to regular 911's that you need a scorecard to understand the "net" effect....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-05-2005, 01:53 PM
Send a message via AIM to Oldporsche
Cool
The "934" developed for racing in "group four". (1974-1978?) The 930 basically was the street version of this car. Some 934's actually were delivered with power windows.
A very interesting heritage.
David Duffield
Old 02-05-2005, 02:30 PM
The weight class that the 934 raced in, not allowing it to be below porker weight...allowed Porsche to keep many comfy items on-board ( like power windows, etc)...
Wil
Wil Ferch
Old 02-05-2005, 06:35 PM
