Why did Turbos get smaller rear sways
Porsche used 20mm rear sways on 86-89 Turbos, but 21mm rears on 86-89 carreras. Any reason why?
Jeff
Jeff C 76 912E 2.6L |
The wanted to reduce oversteer or put another way increase understeer.
Sounds reasonable...so a better match for my 81 SC / 3.6 would be the 22/21 combo from the carerra rather than the 22/20 from the turbo?
Jeff
I'm going along with Bill, but adding reputation on the street. 911's had bad rap about going off the road backwards and the turbos were known to be off/on switches. I'm not necessarily supporting either of these urban myths, but they existed. Look at Detroit, understeer might be slower but safer for the unaware/unexpecting driver. Snap oversteer on the street with little tires and wet dirty roads is a marketing nightmare. Racer's could/will improve the balance anyway.
Was there ever a class to race a "stock" 930 competitively? I can't think of a class that would allow this monster in as a pure showroom competitor.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
I like adjustable bars, if you suddenly don't like something it's easy to try something else.
Tell us how the smaller sway bars increases understeer. Is it because with the softer rear suspension the rear end squats on accellerating thus increased traction in the rear causing the front to plow?
1980 911SC Targa 3.6L |
Diss Member
The reason the smaller rear bar will increase understeer is it allows the rear wheels to be a bit more equally loaded so that end does more work. The front sway bar ends up doing more of the roll limiting and the tendancy towards more unequal loading between the 2 front tires will limit its grip. Wayne |
PMB Performance
I'm using 1976 Turbo bars on my RS clone, front and rear. For this lighter tub they seem to be fine.
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
The relative stiffnes of the suspension on each end of the vehicle has an impact on oversteer/understeer. A softer front end/stiffer rear will give more oversteer. A stiffer front end/softer rear end will give more understeer. Swaybars are just one factor in the stiffness eqaution. Don't forget the Turbo had larger rear torsion bars to go with that slightly smaller rear sway bar.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Turbo had larger rear torsion bars...yes indeed... ( by itself causing less understeer) as well as a wider rear track (....by itself increasing understeer).
Let's now add that the Turbo also has a wider front track ( by itself causing less understeer)....and you'll conclude..... ...There were a number of pro-con changes compared to regular 911's that you need a scorecard to understand the "net" effect.... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
The "934" developed for racing in "group four". (1974-1978?) The 930 basically was the street version of this car. Some 934's actually were delivered with power windows. A very interesting heritage. David Duffield |
The weight class that the 934 raced in, not allowing it to be below porker weight...allowed Porsche to keep many comfy items on-board ( like power windows, etc)...
Wil
