-   -   The build continues, part 4 (http://forums.pelicanparts.com/porsche-911-technical-forum/204613-build-continues-part-4-a.html)
rdane 02-03-2005 10:28 PM
Previous posts:
http://forums.pelicanparts.com/showthread.php?s=&threadid=195181&perpage=10&pagen umber=1
http://forums.pelicanparts.com/showthread.php?s=&threadid=201585&perpage=10&pagen umber=8
http://forums.pelicanparts.com/porsche-911-technical-forum/199341-paint-dilemma.html
All encouraged by project cars like these among many:
http://forums.pelicanparts.com/uploa...1101863180.jpg
http://forums.pelicanparts.com/uploa...1078712626.jpg
http://forums.pelicanparts.com/uploa...1102142780.jpg
Here is where I am today. Epoxy base drying for the first coat of primer and then body color (light blue metalic ) paint going on early next week. New interior going in a few days later. A number of trick things happening on this car you won't see everyday. Really exciting for me to see this project come together.
The tough decisions were body style (to flair or not) and paint color. Decisions made easier by current wheel and tire choices and a unique color.
Hopefully I'll be driving it to the XXX on the 12th. Then back to the shop again for a few days of motor work and she'll be finished.
http://forums.pelicanparts.com/uploa...1107498066.jpg
http://forums.pelicanparts.com/uploa...1107498246.jpg
http://forums.pelicanparts.com/uploa...1107498386.jpg
http://forums.pelicanparts.com/uploa...1107498437.jpg
Jeff Alton 02-03-2005 10:40 PM
Looks great, soooo................ what color??
Jeff
rdane 02-03-2005 10:51 PM
Hi Jeff, color is going to be "light blue metalic" close to cobalt blue from a 2000 Porsche. I first saw it on a '99 C2 in the 2/05 issue of EXCELLENCE that 9ff did as a lwt car. Very close to the '72 gemini metalic blue but a bit lighter yet.
Eric Mckenna 02-04-2005 04:02 AM
dear god!.. I see I am going to have to be Porscheless for a while while Dane gives me the inspiration to do all the stuff i normally only think about... The car is f'ing awesome loooking in primer.. so I know it's going to be IMHO one of the badest machines on this BBS! good work Dane.. damn good ideas you have for the car.. I kNOW it's tough to do but the sunroof delete and shaved raingutters are by far the best cosmetic touches I think.... looks damn nice!
can't wait ( as I am sure either can you ) TO SEE IT FINISHED...
Ciao, Eric
rdane 02-14-2005 10:57 PM
First layer of primer coat. Notice any details missing? Couple more shots of primer and then we start adding color! They have done a bunch of sanding already and it is beginning to feel baby ass smooth. What were the numbers?
Paul Frere in PORSCHE RACING CARS of the '70s.
"Porsche shaved the rain gutters off of a 935 and did some wind tunnel tests of the aero impact. There was a 3% drag reduction and a 23% increase in rear down force. That's pretty signficant.."
RUF cars did this on some Yellowbird and others because it was so effective. Those numbers can't hurt a duck either I suspect ;)
Bet it cuts some wind noise as well.
http://forums.pelicanparts.com/uploa...1108450487.jpg
http://forums.pelicanparts.com/uploa...1108450529.jpg
I am learning patience with this project. Go slow, do it right the first time has been the matra.
Jeff Alton 02-14-2005 11:07 PM
Do I sense a center mount fuel filler in your future??
Jeff
rdane 02-14-2005 11:12 PM
Jeff, it will have an enduro Fuelsafe cell will the fill under the hood :)
As you can see I am getting more excited by the day. And of course selling all the spares I have to pay for this one!
DonDavis 02-14-2005 11:20 PM
I hope you're proud of yourself! You've successfully planted many seeds of inadequacy. Shame on you!
Nice car! I want to do mine the same way! heh heh
rdane 02-14-2005 11:32 PM
Hardest thing about this car is I have never seen one done exactly like it. Driving me crazy trying to image the finished car. It will have unique paint, interior and body work. (at least to me anyway)
When I bought this car I took it one diretcion over a three year period. In that time I learned a lot about the cars and what I really wanted in a 911. My business builds custom products everyday. So it is easy to realise what a guy really needs is one of every model. Since I could only afford one custom car this is going to be it. The next one will be a 996 or 997 and I suspect either will be cheaper in the long run.
The idea with this one was to be able to pull into any group of great Porsches and still have mine be something different with my own signature.
Took me a long time to decide on a narrow body and the mods. Once I got started it was what "would I have ordered from Porsche". Then I just let my imagination run.
Hope you guys are enjoying the ride as much as I am and it helps send you on to your own adventure!
KobaltBlau 02-15-2005 12:06 AM
Cobalt Blue:
http://bitjug.com/968pics/IMG_0354.JPG
is darker than gemini blue. I think you should paint it one of the IROC colors.
Jack Olsen 02-15-2005 12:13 AM
What was the method for re-welding the gap where the rain gutter seam had been? I've heard that it's a pain in the neck to do.
rdane 02-15-2005 08:52 AM
Jack it is a cut and weld affair. Start at both ends, cut and seam weld a bit at a time (4") and keep moving around so you don't get any warping. A piece of rod fit the gap perfectly. More labor involved chopping the gutters than doing a steel wide body. I went for less lift.
This is NOT how Mark @ Eurotech did mine. But an interesting thread none the less. I have been told it makes the car more rigid if done right. Less if done wrong. I had zero filler added when they were done...just a clean sheet of steel with little grinding to clean it up.
That says more about Mark as a welder than the process I suspect.
http://forums.pelicanparts.com/uploa...1102616118.jpg
http://forums.pelicanparts.com/showthread.php?s=&threadid=196103&highlight=shaved +rain+gutters
Andy, sadly it isn't an IROC car. A clone would have been easier to decide color on. Beautiful color you have picked though. There are so many good colors it was really hard to choose just one. Hopefully the "ice blue" will be something I can live with and still have it jump out at you in a crowd.
Eric Mckenna 02-15-2005 09:39 AM
I'd love to see a good thorough write up on the method yer man used.. I would ove to have that done when the time comes for me to park the car for a while and REALLY get down to messing with it. I'd go with that Mint/celeste green they had on the Euro 964 RS'd.. that' the color I am going with when the time comes.:) next to NO ONE has that color here in the US.. oh boy now watch everyone will have it. .. this will be ONE damn nice car Dane.. IMHO one ofthe best on this forum...I love hwere it's going.
-Eric
Eric Mckenna 02-15-2005 09:46 AM
Dane have the back's of the buckets painted to color match the car.. that is a sweet look IMHO..
This is something I plan on doing to mine when the time comes..
http://forums.pelicanparts.com/uploa...1108489590.jpg
Cory M 02-15-2005 09:47 AM
If the guy who shaved the raingutters was able to do it without using any filler that's pretty amazing. Must have taken him forever, it's pretty easy to overheat a roof panel and cause it to warp if you move too quickly. Car looks great looking forward to seeing the finished product (although a project car is never really finished).
MotoSook 02-15-2005 09:48 AM
Looking good Dane! I can't wait to see it finished. I debated over the rain gutter delete job on my car, but my available time to work on the car won't allow for it. I'll do it on the next car...
Reg 02-15-2005 09:49 AM
Hey Andy!
That's a great house (and car) you have there. If you have any pictures of the porch I'd love to see more.
BTW I like the cobalt blue as well! :)
Regards,
Reg
rdane 02-15-2005 09:58 AM
Great idea Eric, love the look. My interior is a blend of the original cork brown and black...so no need to paint the seat backs. I think you'll approve when you see the finished product. At least as much detailing in the interior as the exterior. Hopefully it will show. I want to see that green and seat colors on your car! That is a great color you have picked.
The new engine will be visual treat as well.
Jeff Alton 02-15-2005 11:00 AM
Stoopid me didn't even notice the rain gutters, or lack there of. That is a cool mod! Love it. Your wheels are going to look good on my car. Glad I could help with the funding of the project :) Wanna sell the turbo brakes?
Jeff
Craig 930 RS 02-15-2005 11:32 AM
WOW.
That car is gonna be completely transformed.
I really like unique builds.
Way to go!
randywebb 02-15-2005 11:40 AM
It was pretty signficant... but you probably aren't going to be at the same speeds as the cars that generated that degree of benefit - and it's non-linear. I do expect you'll get a reduction in wind noise.
It's still an interesting project and please post more info as you proceed.
Jack Olsen 02-15-2005 12:06 PM
It looks awesome.
Are we shooting for a CTR Yellowbird look in blue? A 3.4-liter Bluebird?
http://forums.pelicanparts.com/uploa...1108497961.jpg
Scooter 02-15-2005 12:44 PM
Jack, a Yellowbird is not modified enough for Dane. He is going many steps beyond, e.g., Jack Olsen land. ;) How about Blue Beauty? LOL
randywebb 02-15-2005 01:12 PM
That's Ok, but "Baby Blue" and "Baby Blue II" are already taken...
rdane 02-15-2005 02:22 PM
Think duck and a narrow body IROC front in ice blue...not baby blue :)
Ice blue as in Cold Duk.
Craig 930 RS 02-15-2005 02:29 PM
Blue car......Dane, you still doing the vanity plate "RBRDUCK"?
Remove the heating and call it COLDDUK;)
rdane 02-15-2005 03:09 PM
Still, RUBRDUK Craig. My rubber duck at that, no matter the color :) Added another twist today...pictures when I get a chance.
Thanks for the comments guys!
Motor is still in the works.
Depends on how many body parts I sell in the next few weeks how far I take it.
Suspension is nothing new, sport Biltsteins, rsr struts, lowered spindels, Elephant mono balls or poly bronze on the rest, 22/30s Sanders, Carerra sways, 930 brakes with floating rototrs in front and a brake bias valve in the cabin. Last thing going in will be the Wevo camber plates with roller bearings for the rear. Rims are off to Al Reed for the RSR look.
It'll look different but pretty much drive the same with a bit more power.
Craig 930 RS 02-15-2005 03:15 PM
Engine:
Take er all the way. One shot deal.
The ultimate 3.4!
rdane 02-15-2005 03:16 PM
Craig they buy the right body parts and it won't be a 3.4 ;)
Craig 930 RS 02-15-2005 03:24 PM
More power to ya.
"It's all about 'Power to Weight' "
rwpiper 02-15-2005 03:45 PM
Dane, Holy sh*&%! You have gone off the deep end! What a cool car; an Excellence candidate for sure. I can't wait to see the finished product. Will you be using chrome trim?
Craig 930 RS 02-15-2005 03:47 PM
The deep end is a great place to swimhttp://www.pelicanparts.com/support/smileys/loki5.gif
Craig 930 RS 02-15-2005 03:52 PM
Correction:
.......I've learned that my 'water' is made up of $$$ signs, not aqua blue goodness:p
rwpiper 02-15-2005 03:53 PM
Apparently I'm still in the kiddie pool....
Dane, how was the sunroof delete done? I would love to make this mod, as I need new paint on the roof and a new headliner anyways so I "misewell" delete the sunroof. I've seen it done by replacing the whole roof skin and also by welding in the original panel.
KobaltBlau 02-15-2005 03:54 PM
Ice blue isn't metallic, is it?
Originally posted by Reg
Hey Andy!
Regards,
Reg
Reg, the house is not mine, but in a whimsical neighborhood. I don't own the car anymore either but will always like the color. the car is a '92 but porsche's 997 cab launch info on their website right now features the same cobalt blue.
rdane 02-15-2005 04:00 PM
Hey Bobby! I just asked Mark and Phil @ Eurotech to comment here on some of the body work they do. Us locals are lucky to have them around.
Seemed easy enough watching them :) More importantly the price was right. Perfect mod when you need to respray the roof.
KB, this ice blue is a light metallic or pearl can't remember which.
island911 02-15-2005 10:49 PM
Shaved!? -- Daaaammnn, Dane.
rdane 02-16-2005 07:13 AM
I'm liking the name "SCHICK" for this car. Island, guys what do ya think?
island911 02-16-2005 08:25 AM
:D oh yeah - perfect.
. . . that name is smooth. :cool:
Shuie 03-05-2005 08:18 AM
Smoothie :)
This was a damn fine car before it went under the knife. It is going to be even more incredible when its done. Nice job! Blue with rough anodized fuchs is going to be awesome.
Make sure you tell Al to make them more powdery white than silver. When he did mine they didnt exactly come out as white as the RSR finish is supposed to be. Im sure he can do it now, but at the time my wheels were his first attempt at this finish.
