Brake System Reset
When I rebuilt the car I noticed that someone had disconnected the two wires that were on the master cylinder so I reconnected them. I just got the car back on the road and now I have a blinking e-brake light that won't go out.
Zeke Wrote: "You replaced the master cylinder, I'll bet, and didn't set or reset the little stem under the rubber boot on the left hand side underneath.
Push on the rubber until you feel the tip and puch it in until it stays.
This is your system warning switch and is monitored by your ebrake light."
I Just went under the car and removed the skid plate but I can't find any little stem under a rubber boot to reset. Can I assume that if I replace the switch that the two wires are connected to, it should solve the problem?
Jim T.
87 911 Carrera
Guards Red Coupe
Cat Bypass, SW Chip, 7's & 9's
Old 02-07-2005, 05:26 PM
I just went looking and noticed that Pelican shows 2 warning switches for the 74 master cylinder. I only have one. What's up with that? Could I have an incorrect master cylinder?
Jim T.
87 911 Carrera
Guards Red Coupe
Old 02-07-2005, 05:43 PM
Early_S_Man's Avatar
Porsche Crest
Jim,
The pic [diagram] is incorrect ... that is a power-boosted master cylinder for '77 models and later, and yours isn't boosted.
Your master cylinder should look like this one:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-07-2005, 10:16 PM
OZCarrera3's Avatar
I had this issue with my car after doing a replacement of the brake fluid.
After mucking around trying to find reset switches etc, I eventually fixed it by disconnecting the battery and then re-connecting it! (Note mine was non-boosted too)
No *****!
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 02-07-2005, 10:22 PM
Now in 993 land ...
aigel's Avatar
I second this. The system should be resettable by disconnecting the battery. No reset switches on my SC either.
George
81 SC (sold)
Old 02-08-2005, 12:25 AM
I agree with Zeke. On a 74-76 911 the reset switch is where he said it is, assuming that your master cylinder is still stock. It is, indeed, hard to see and access. But it's there. Try pushing with a wooden dowl, or a long, skinny finger.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 02-08-2005, 04:45 AM
Yes, I did the brakes on my 1975 911 with new master cylinder. There is a little white miple that needs to be pushed in to reset. Look close it is there.
1975 911 Carrera BLK/BLK
Old 02-08-2005, 05:46 AM
I'll look again guys but I have a hunch that the M/C is not a stock one.
Jim T.
87 911 Carrera
Guards Red Coupe
Old 02-08-2005, 06:12 AM
Don Z.'s Avatar
Only because I'm hoping I did it right when I did mine (the alternative being that I was very lucky)
Is it the nipple on the switch, black in this photo, that the "red arrow" points to?
If it is, then I did it right. If it's not, I'm off to grab a couple of lottery tickets...
Old 02-08-2005, 07:07 AM
OZCarrera3's Avatar
I'm telling ya, disconnect and reconnect the battery. Its alot easier and it works. I have not had any trouble since using this method.
Cheers.
Sheldon
'07 BMW 335i
Old 02-08-2005, 04:18 PM
I tried that Sheldon, didn't work. I think I have a bad sensor switch.
Jim T.
87 911 Carrera
Guards Red Coupe
Old 02-08-2005, 04:42 PM
OZCarrera3's Avatar
Damn, boy is my face red! Well, can't win 'em all.
Hope the sensor switch solves your problem.
Cheers.
Sheldon
'07 BMW 335i
Old 02-08-2005, 06:01 PM
Zeke's Avatar
The red arrow is pointing to the correct place. OK, you pushed it in, but you're not done yet. The old m/c had 2 spade terminals on the switch and now you only have one. However, you still have 2 wires going down there.
Oh, my, what do you do???
Using a testor and with the ignition on, find which one is hot. Connect to the single terminal. Make up a short wire with a female spade connector on one end and a ring connector on the other. Attach to m/c or body as a ground. Or, just strip the wire that is not hot and ground it.
Old 02-08-2005, 06:26 PM
