Removed alarm, starter kill switch???
Hi,
I just removed the alarm in my '73 911. It was a pretty clean install and the only wire affected was the starter wire which was cut near the ignition switch.
Well since the wire is cut, I wanted to wire in a starter kill switch. It won't prevent someone from push starting the car, but it might stop someone from a stupid joy ride. What kind of switch should I get? I am worried that I might not get a switch that can handle the amperage going through that wire.
Thanks,
Neil
Neil
'73 911S targa
Old 02-06-2005, 07:09 PM
Early_S_Man's Avatar
Porsche Crest
Neil,
If you want a foolproof switch that completely disables starting or running ... but will still be able to be cranked, forget the #50 STARTER LEAD -- just splice it back together. Instead, find the Black/Violet wire to the tach ... and use a switch to ground that lead! The engine won't fire as long as that lead is grounded. Not even with the key in the ignition!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-06-2005, 07:47 PM
