19 years and 17k posts...
azasadny's Avatar
Looks great, congratulations!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-07-2005, 03:51 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I'm a little curious why your case doesn't have a sump plate and it's an SC? Thought this came around in the 3.2 engine.
Just curious.
BTW, nice job.
Old 02-07-2005, 04:10 PM
Jays72T's Avatar
Very nice work.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 02-07-2005, 04:23 PM
Virginia Rocks!
VaSteve's Avatar
I wish I could have stayed for the test ride, but the in-laws were visiting and if I ever hope to see my car again, I needed to get home to a appease mom-to-be.
Participating in the sucessful reinstall (and the 60 degree weather yeasterday) became the kick in the ass I needed to get my project back on track.
This particular car is a very late '83. They started using the new cases with the 3.0 cylenders before the Carerras came out.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-07-2005, 07:16 PM
bigrubberjeep's Avatar
Very nice work. Looks great too, my motor is 50% of the way there too.
I can't wait!!!!
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 02-07-2005, 10:00 PM
Why did you replace your injectors?
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 02-08-2005, 05:43 AM
Rick Lee's Avatar
Because they were there. Because I could.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-08-2005, 06:01 AM
JBO JBO is offline
It looks like you used dilavar studs instead of the 993 steel studs, is that correct? I went with the 993's.
Old 02-08-2005, 08:39 AM
Rick Lee's Avatar
They are most certainly NOT Dilivar. Have to check my receipts, but I thought they were 993 epoxy studs.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-08-2005, 08:41 AM
Irrationally exuberant
ChrisBennet's Avatar
Just curious.
BTW, nice job.
The sump plate change happened in '83 so some SC's had the later style case.
- Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-08-2005, 08:55 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
The replacement studs are epoxy coated steel (stick nicely to magnet). The 993 studs are also listed as fully threaded DILAVAR.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 02-08-2005, 09:09 AM
Some 993 studs (993 101 172 02) are steel.
-Chris
Old 02-08-2005, 09:29 AM
Senior Member
Superman's Avatar
Rick and others, yes you can re-ring Alusils. I know you didn't re-ring, but still, there was a chance that your cylinders could smoke, particularly if you idled it at first. If it doesn't smoke now, then you got away with that.
I continue to believe that getting the cylinders really cleaned, etched almost, was perhaps the secret. I re-ringed my Alusils at about 180K miles. The were WELL within spec. The most wear we could find on any cylinder was .0015" !!! Ring lands were very tight, also well within spec. Ring gaps were at the outer edge of spec. So, we put them in John Walker's BFPW (large parts washer) which changed the appearance of their business surface. Bruce Anderson said not to be gentle with this engine. I drove it within two minutes of startup, accelerating and decelerating. Today, probably 100k later (odometer broke), still no smoke whatsoever. Thing runs like an ape with its hair on fire.
For more info, do a Search. There is a LONG thread on the engine rebuild forum. Re-ringing Alusils has been discussed here ad nauseum.
Mocha 1978 911SC. "Coco"
Old 02-08-2005, 09:50 AM
