gerard vaglio's Avatar
maybe size does matter? Pix!
Car won't start?
I'm installing an Odyssey battery in the smugglers box of my sc. The battery is the remarkably small, 15lbs, PC-680.
My question is that when I hook it up and try to start the car the engine turns over great, but it won't start.
So I give up, I hook up the terminals to the old battery and the car starts.
Am I born to lose, what is the problem here???
Old 02-08-2005, 06:07 PM
Licensed User
Shuie's Avatar
Nice watch!
I used to have a PC680 and never had any problems with starting my '72 2.4 MFI motor.
Old 02-08-2005, 06:10 PM
19 years and 17k posts...
azasadny's Avatar
Nice bracket! Has the battery ever worked? Maybe you got a "dead" battery?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-08-2005, 06:13 PM
If the engine is turning over fast but not starting could the battery be low?
Old 02-08-2005, 06:17 PM
pjv911's Avatar
Send a message via AIM to pjv911
Hook up the additional cables that the orig battery has . Accessory cables that is .
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-08-2005, 06:29 PM
I'll bet there's a separate wire coming off the terminal for the ignition that's not making good contact when you bend the cable over to the smuggler's box.
Anyway, what's with the watch?
C.W.
Charlie
'67 S Tangerine
Old 02-08-2005, 06:36 PM
Every PC-680 comes with a commemorative watch.
Actually, I placed it there for scale for people who have not seen this battery. I'm very proud of this battery, the only thing that could make the moment more special is if the car would start.
Old 02-08-2005, 06:43 PM
Brother's Avatar
Is the oddysey a gel cell or a lead acid.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 02-08-2005, 06:59 PM
I believe it is a sealed lead acid battery but the seal is so good it an be installed on its side.
"based on the same battery technology offered to the military for aircraft and tank batteries. Odyssey batteries are of military grade and have endured rigorous tests that demonstrate their overall ruggedness and exceptional tolerance of mechanical abuse.
Works in Tanks and aircraft , maybe if I make some airplane sounds it'll work.
* 6 to 10 year service life
* 99.9% pure lead providing minimal plate corrosion
* Explosion proof
* Corrosion proof
* 2 to 3 times the cranking power of equilivant size battery
* Spill and leak proof
* Superior vibration resistance
* Fully Charged out of the box
* When fully charged can be stored for up to 2 years at 77¡F
* May be installed on its sides at any angle without sacrificing
performance attributes
* Won't start Gerard's 911
Old 02-08-2005, 07:53 PM
Kurt, you were right, I missed on of the accessory cables.
Car started, I'm happy. Embarrassed but happy.
Old 02-08-2005, 10:16 PM
bigchillcar's Avatar
I was going to say move the watch and try firing her up...
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-08-2005, 10:33 PM
another round please
strupgolf's Avatar
If I can ask, what does that battery cost? Ive never seen one like that. Thanks
Getting old is not for wimps.
Old 02-12-2005, 03:51 PM
Bird. It's the word...
Fishcop's Avatar
Same battery as I use. Out of interest the "parent" company is Hawker de Haviland.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-12-2005, 04:24 PM
Hi strupgolf,
The battery costs $90, about the same as a regular battery and ONCE INSTALLED CORRECTLY, works just fine. I've been using it for a few days now and no troubles. I still can't get over the size.
And now that it's relocated behind the front wheels I "believe" that the car handles better because I want to believe.
Old 02-13-2005, 09:26 PM
KobaltBlau's Avatar
gerard, you are funny, not because you screwed up but you just have very funny comments. maybe you should post more often
Andy
Old 02-13-2005, 09:52 PM
ScottKelly911's Avatar
Send a message via AIM to ScottKelly911
Gerard, great set up, I've been thinking about doing the same for my car, where did you get the battery mounting relocation kit and for how much? Thanks
Gruppe B #22
Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6
Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo
Old 02-14-2005, 12:15 AM
