front strut confusion
I'm trying to figure out what to use for my front suspension on my 914 track car
Here's a couple of things I want/need...
- I need SC or 3.2 struts (3.5" brake caliper mounting)
- I'd like to run the yellow Koni dampers (because of the adjustability) instead of the Bilsteins
This would mean I should get a set of Boge or Koni struts, but since I'd also like to raise the spindles, that's only possible on the Koni struts
I tried searching PET, but I can't find ANY info there on the Koni struts...
Were those available with the 3.5" brake mounting spacing?
Also, will the yellow adj.Koni's fit a Koni strut?
Koni lists seperate stock dampers for Boge and Koni struts, but just one type of yellow adj. damper
Any input is appreciated!
cheers,
Jeroen
Old 02-10-2005, 09:03 AM
I would rather be driving
jpnovak's Avatar
YOu can get Koni struts. They were found on some early (pre-73 911S) cars and also as an option on the 74-77 cars. I think they continued through the SCs but am not postive. They are available but not as common to find compared with Boge or bilstein
Old 02-10-2005, 09:12 AM
914_2sj's Avatar
Koni struts were all 3.5" brake caliper spacing. But be careful you don't get the very early struts as there are no spare parts available for them.
Funny you should mention raised spindles. I just got my pair of raised spindle koni's yesterday.
Old 02-10-2005, 09:13 AM
I'm confused.....
I thought only the Bilsteins allowed raising spindles because this design does not have the "collar" welded above the spindle support ? ( I know, I know...Chris Bennet knows a guy.... who knows a guy ....who raises Boges spindles...but in *general* it seems to only work with Bilsteins).
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-10-2005, 09:14 AM
914_2sj's Avatar
There's enough room on them to raise. Mine are raised 19 mm
Old 02-10-2005, 09:24 AM
"Them" = Koni's ????
Really? .....
Wil
Wil Ferch
Old 02-10-2005, 09:29 AM
zotman72's Avatar
Dave at Dartauto in Denver will raise your spindles on whatever strut type you have. HTH. www.dartauto.com
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 02-10-2005, 09:33 AM
914_2sj's Avatar
[QUOTE]Originally posted by Wil Ferch
[B]"Them" = Koni's ????
yep sorry yhem = koni.
I'm looking at them right now.
Old 02-10-2005, 09:34 AM
PMB Performance
Eric_Shea's Avatar
My Koni's are raised 18mm. They are "SO" close with my 15" wheels
You can only raise the Koni's 18-19mm. After that you're bumping up against the flare in the strut body. Now, that being said, there are other methods of raising them. I believe Racer Chris can do about anything.
Yaaa-Rooooon... I like early Koni or Bilsten complete front ends. This way you get the 19mm t-bars and thru-body sway bar mounts. Koni's are adjustable. Bilsteins are solid right out of the box.
Your choice.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-10-2005, 10:03 AM
PMB Performance
Eric_Shea's Avatar
Here's a set that was raised...
855-STOP-101
Old 02-10-2005, 10:04 AM
914_2sj's Avatar
Re: front strut confusion
cheers,
Jeroen
From the info I got from the koni website, you can use the yellow koni sports on oe koni struts if you get a special koni gland nut.
Old 02-10-2005, 02:17 PM
thanks guys!
for a minute I was worried that I was looking for an impossible combination...
now all I have to figure out how much springrate the yellow Koni's can handle max.
I'll try and call Koni tomorrow to see what I can find out about that
Then I'll go shopping for a set of struts
Old 02-10-2005, 02:18 PM
914_2sj's Avatar
thanks guys!
I was in the same boat when I started looking for yellow sports yesterday.
Old 02-10-2005, 02:22 PM
914_2sj's Avatar
yellow koni's on koni struts
Well after 4 months of waiting on a pair of yellow koni's to arrive from England they finaaly arrived and found that the gland nut that my koni struts came with holds the shock fine except that it sticks out. Does anybody have the specific dimensions of the special koni gland nut that koni says to use with the koni struts and koni yellows?
here's some pics of my koni strut and shock and gland nut.
Old 07-10-2005, 06:38 PM
