Rear Bumper Height for Engine Drop
Please Help -
Dropping a '83 SC with 3.0 engine to fix oil leaks. What is the height needed at the rear bumper to remove the engine and transmission from under the vehicle (clearance)? Rear valance and bumperettes have been removed. I curently have it jacked up 25 inches (from bottom of the bumper to the ground), and it just doesn't seem high enough for clearance. Jack height is 6 inches high fully lowered (using an ATV jack). Help is much appreciated!
If it has a skirt or tires, it WILL cost you money! |
I think you're looking at more than 30 inches.
Are you not able to jack the car high enogh with your existing jack? jack the car up to a reasonable height and then drop the engine using the ATV lift.... leaving the engine under the car. then... use a regular jack on the sides of the car at a lift point or the jack pad to get the car as high as you need it. you can do the reverse thing when you put the engine back in so you dont have to raise the engine up as much to reinstall. -bernie
Database and Website Consulting Services in Chicago |
I think Bernie is right, it's over 30 inches. Where are you supporting the car? I used jackstands supporting under the rear torsion bar covers, with about 8" of wood blocks to add height for the jackstands. I think the jackstand height was about 26" at the T-bar covers, which was enough to slide the engine out.
'85 Carrera Coupe, White Gold Metallic - 8" rear Fuchs, Fittipaldi steering wheel, Weltmeister short shift, Turbo tie rods. "If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donohue Last edited by Carrera Sled; 02-12-2005 at 06:11 PM.. |
UFLYICU
I think you can see the general height required in this pic. It is scary, and make sure you chock the front tires. Notice the AFM has been removed to help.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Thanks guys. I'm supporting the car with jack stands at the torsion bars as recommended in Wayne's book. My jackstands go to 25-26 inches in height (Craftsman 6 ton jackstands), and I've currently got them at about 17 inches, so I have room to move. I was just a little concerned about the stability. Man, a lift would be nice
remember ZOANAS is 7'8" tall
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Friend of Warren
24" at the bottom of the torsion tube covers will have it up high enough.
Kurt V No more Porsches, but a revolving number of motorcycles. |
