oxygen sensor
today while driving my oxygen sensor light came on and the passenger side window stopped working...i doubt the are related..though they both happened at the same time. Car appears to be driving as normal ???any ideas??? should i be concerned?
1982 911sc coupe blk/blk 2004 Mercedes ml350 2003 Nissan Maxima 2005 infiniti g35 coupe 6mt 1980 Maserati Merak-gone-thank god Ferrari 250gt cal spyder replica |
ps...car has no cat just a through pipe
Sounds like you need to reset your o2 sensor behind your speedo. I had to do mine also awhile back, then I just disconnected it for good measure
Matt '82 911SC Targa! |
The light doesn't do anything except remind you its time to replace the o2 sensor. It just comes on 30,000 miles after the last time it was reset. At least I think it's 30,000 miles.
-Mac |
If you're unsure about the condition of your O2 sensor, you should probably
disconnect it. The SCs Lambda unit will set the frequency valve at a 50% duty cycle which in turn will set the fuel mixture at a nuetral position, i.e. not too rich/lean (which a bad O2 sensor may cause). In either case, lean/rich mode could cause problems, e.g. damaged CAT, burnt valves.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
