Car was standing for plus-minus 5 years. Removed and cleaned out fuel tank, refit, fit new fuel pump, new fuel filter. Fit recon fuel distributor, warm-up regulator strip and reset, new plug leads, new injectors. Cold start, no problem, revving-up smoothly, after driving about 4km's starting to back-fire and misfire.
Problematic until cooled down. Main fuel pressure 5.2bar & control pressure 3.7bar. Injectors quantities have been calibrated. Anyone had similar problem? |
ROW '78 911 Targa
Any problems starting it when warm?
Have you set the mixture up with a CO tester? All vacuum lines new? New distributor cap and rotor? Timing settings?
Really sounds ignition related. Try swapping out to a known good CDI box and run the test again.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Sound like a lean mixture problem. Check pop off valve see if it's seated properly. Check for vacuum leaks. Did you check and set mixture if so how ?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Fleabit peanut monkey
kodioneill is on target. Your control pressure is way too high - for starters. If you knew enough to check the pressures why didn't you know what your pressure operating range was?
3.4 bar is your max warm control pressure at 40C - 104F. That's pretty f**king hot for November.
1981 911SC Targa |
1981 911SC Targa |
ROW '78 911 Targa
Actually Bob I believe the graph is for Cold control pressures. (As per box beside it)
His Warm control pressure is 0.1 bar higher then what it says in the chart next to the graph.( 3.2-3.6 bar) His system control pressure should be 4.5 to 5.2 bar car off, pump running. His readings are at the top end of the scale. I'd be more interested in the residual pressures when warm and the CO mixture he has. Also Ignition and timing conditions.
Yep - I gotta eat shiet on this one. Sorry to the OP for coming off like a jerk. I'm not really, just only when I am. heh heh.
1981 911SC Targa |
