PAT4's Avatar
Lowering front susp. and camber
Hi all,
When lowering seriously the front of an early 911 (1970) does this modify the camber adjustment of wheels ?
If yes (I suppose yes) do you have an idea of the relation between lowering and camber modification
Something like, by example: 5 cm lowering => 1° more negative camber
Old 02-20-2005, 12:46 PM
ipapilot's Avatar
Most if not all of the change is in 'toe'.
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 02-20-2005, 02:33 PM
jluetjen's Avatar
I suspect that if you are seriously lowered by indexing the T-bars, that you'll lose static camber at the front. More importantly, you'll be way "over the top" with your dynamic camber and be losing camber in bump and gaining it in droop which is pretty much opposite what is desirable.
Now if on the other hand you've lowered the front end by raising the spindle, the change to your chamber (static and dynamic) should be negligible from stock, but there still may be bump steer issues. Here's a bunch of previous threads on the subject.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-20-2005, 03:23 PM
PAT4's Avatar
Thank you john.
The fact is that the car I bought IS very low in front (about 63 cm at the top of front wheel arch (195/65x15 tires) and I can see a significative negative camber.
I wanted to know if I should first make the car up before looking at camber alignment on strut heads...
Old 02-20-2005, 11:06 PM
To see how much the camber changes just put a 2' level on the front tires, start jacking the front end up with a floor jack at the cross member in front of the gas tank and watch the camber change every half inch as you jack it up.
Cheers,
Joe
Old 02-21-2005, 07:45 AM
PAT4's Avatar
so simple, so evident ...
simply many thanks !
Old 02-21-2005, 12:44 PM
