Me like track days
VERY short primaries - almost like a 996 header - very different from what I am used to with 3.6 header/exhaust systems.
Does this "make sense"? Any educated guesses?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 02-22-2005 at 03:28 PM.. |
Me like track days
Got pic to load:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
RETIRED
They look equal length...does the maker have any dyno time with them?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Me like track days
He does. GHL said to the owner of this system that he did use a dyno to test & develop them -
RETIRED
Then what's the problem? Too pricey? Looks like less to rust....
Me like track days
No 'problems', Mike.
See my original post which considers the theory of the design -- way different than any other air cooled header I've seen - ULTRA short primaries! We want to see if this makes any sense before in$talling on a built up beast of a 3.6 -
RETIRED
Well to answer your original question...no, never seen them that short. My 3.6 SC has the classic bag of snakes design header that I may remove one day and put custom heat exchangers back on. This winter has been a bit of a bear even in CA.
If the maker has good dyno numbers,....I don't see any reason to dispute them if he or the dyno operator has a good reputuation....
turbo dreaming
Definitely goes against conventional N/A header design. Runners look like they belong on a turbo car. I don't see any benefit of going with such insanely short primaries.
The flat collector design looks pretty crappy and archaic. Nothing revolutionary there. In fact, I would say the stock heat exchanger design looks better in this area.
Princeton Wong 96' 993 Carrera 2...Turbo As seen on MaydayGarage: http://goo.gl/mGmZB In Excellence #191: http://goo.gl/BjOsn |
Not much too them. Are they cheap? (nothing GHL is cheap....). I bet they are loud. Is that one of the reasons why rear engine cars are so loud -there exhaust sustems are so short?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Neither is "better" or "best", but rather a different horses for different courses kind of situation.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
From a performance point of view, no, you want long(~31") primaries in the power ranges a street/track car sees the most You might as well use tock 993 headers and fan up some mufflers like Mike F. did.
turbo dreaming
Bill expressed my thoughts exactly. Just more elegantly.
Out of curiosity, whats the asking price?
Me like track days
Yeah, Bill & Princeton - I thought the same thing.
A buddy of mine bought these........and I wasn't too high on the design principle. They are spendy units - and built like a tank. You should see 'em in person - they put some serious work into these - thick, multiple, sections, beautifully made. Just not sure about the design - BUT they do have short primaries like the 993 units......that had me curious.....
Bad idea IMHO.
Believe it or not a 5.8 liter engine is considered tiny in drag racing terms and the lack of torque (more than a 3.6) is ususally "fixed" with long tube equal length headers. Typical drag V8 runs 22-25" primarys, torque rules the street and most tracks of any kind. Headers are a great way of expanding any engines powerband. My old drag 410" V8 made more torque anywhere in the rpm band than a typical 911 motor and I ran 2" primary 23" L headers into 4.5" collectors. Longer primaries can extract torque from a small motor while giving up little in the way of max HP. Add to that that the collector design is seriously lacking and I'd say it's a bad deal. What we need is large tube SSI's or similar. I think those of us in the 911 hobby often get caught up with the idea that we can run "stock location" headers that mate up to conventional exhaust. Find a header with a long primary of decent size and find a muffler that will compliment them. To put my money where my mouth is I own a pair of Bursch headers but will be building my own custom set for my track car.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
