Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
RSR shocks, special hardware to mount?
IF I want to put the RSR coilovers on my car, 1972 911T, do I need any special hardware for the upper mounts? I was planning on using the Elephant Racing monoball in the Elephant Racing camber plate mount. Is that all I need to bolt the coilovers in?
74 911s neverending story. two feet and a jetta for now.
Old 02-23-2005, 11:00 PM
anyone?
Old 02-24-2005, 02:02 AM
alfizzo's Avatar
call the racer group.
Old 02-24-2005, 04:28 AM
Do call Chuck Mooreland or others...but my opinion is this:
Be careful in that the loads are now through a different path....the coils will now load up the shock towers..something they were never meant to do originally. RSR coil-overs are best used when the shock towers are re-inforced or tied into a roll cage structure......
IMHO......
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-24-2005, 07:25 AM
Jeff Alton's Avatar
Thw shocks come with there own mounting hardware, however you should reinforce the chassis in that area.
Jeff
www.turn3autosport.com
Old 02-24-2005, 07:27 AM
Chuck Moreland's Avatar
You need hats and the coils. You can also put in a bearing kit to prevent wind-up when steering, though the monoballs will largely mitigate the need for this.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-24-2005, 10:59 AM
Ah just the man I was hoping to hear from. I assume you sell the springs and hats even though they are not on your website. A call to Elephant is going to happen sooner than later. Now if I only had more money....
Thank you Chuck.
Old 02-24-2005, 11:16 AM
