Gearshift lever rotating HELP!!!!
77 911 gearshift lever rotates where it comes together at base.I was having trouble shifting into 5th wihtout nicking reverse.I thought it was shift rod adjustment problem. turns out the gearshiftlever is loose and rotates when shifting into reverse thus cant get in reverse or 5th. Is there a pin holding things together I couldnt see one . Anyway what do I do to fix it?
Friend of Warren
This same issue has been discussed just in the last week. Yes there is a pin. It has probably come loose or the epoxy holding the two parts of the shift lever has deteriorated.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks Kurt, didnt see a pin are some years epoxyed and some pined? any one have pics?
When mine did this, I put a bit of JB weld in the coupler where the shaft sits.
I had tried epoxy but that didn't last long.
Mark H Class Race Car Project Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S |
Thanks Mark, I put some JB weld where the shift lever comes together at the base. I will check it out after it sets up.
The 915 shift lever is made of two pieces. The lower piece (as you know by now) is glued. I suggest tack welding for a permanent fix (make sure they're in the correct alignment).
![]() Other shift housing mods here Sherwood |
Thanks alot man!! I just tried the JB weld , you gest it ,it did not hold.so I will have it tack welded. I assume the correct alignment is when your in 5th and the gate is flush up agianst the gearshift lever.
I'm surprised the JB didn't work.
Did you put it around the joint, or squirt some down in the hole with the shaft out?
" I assume the correct alignment is when your in 5th and the gate is flush up agianst the gearshift lever."
Yes, that's right. And if the lever doesn't fall directly at hand, you could manage a bend in the lever (with extreme heat) to improve the ergonomics. Sherwood |
Location: member Central PA Region PCA , Home of the Hershey Swap
regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
