RSR shocks, special hardware to mount?
IF I want to put the RSR coilovers on my car, 1972 911T, do I need any special hardware for the upper mounts? I was planning on using the Elephant Racing monoball in the Elephant Racing camber plate mount. Is that all I need to bolt the coilovers in?
74 911s neverending story. two feet and a jetta for now. |
anyone?
call the racer group.
Do call Chuck Mooreland or others...but my opinion is this:
Be careful in that the loads are now through a different path....the coils will now load up the shock towers..something they were never meant to do originally. RSR coil-overs are best used when the shock towers are re-inforced or tied into a roll cage structure...... IMHO...... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thw shocks come with there own mounting hardware, however you should reinforce the chassis in that area.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
You need hats and the coils. You can also put in a bearing kit to prevent wind-up when steering, though the monoballs will largely mitigate the need for this.
Chuck Moreland - elephantracing.com - vonnen.com |
Ah just the man I was hoping to hear from. I assume you sell the springs and hats even though they are not on your website. A call to Elephant is going to happen sooner than later. Now if I only had more money....
Thank you Chuck.
