newb.
eimkeith's Avatar
will this LSD diff work in my Carrera 3?
I have a factory LSD, part number 930 332 053 02, in my 931. Will this LSD work in my '77 Carrera 3?
I can't find any info in PET about the Carrera 3, much less the diff it takes...
If the diff will work, I need to pull it before I let the 931 stuff go!
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 02-26-2005, 06:24 AM
beepbeep's Avatar
931 diff is same as 915 one which is same as early 930 one.
Crown wheel isn't though.
Thank you for your time,
Old 02-26-2005, 06:34 AM
newb.
eimkeith's Avatar
Crown wheel is the ring gear? If so, it should be interchangeable with the one on my Carrera's open differential, right?
keith
r gruppe #436
Old 02-26-2005, 06:54 AM
jluetjen's Avatar
In order to prevent having to readjust the backlash in your transaxle, I'd transfer the LSD onto your existing ring gear rather then swap the complete LSD and ring-gear assembly. This is because the ring gears and pinion shaft are matched sets. You'll notice that they should be scribed with matching numbers.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-26-2005, 07:05 AM
beepbeep's Avatar
What I'm trying to say is this:
931 ring gear (the cogged thing around the LSD) isn't compatible with 915 ring gear, as far as I know. LSD itself is the same.
So just unbolt LSD and move it to you existing 915 ring gear.
Old 02-26-2005, 08:43 AM
newb.
eimkeith's Avatar
right on. that's the info I was after.
NOW - rumor has it that 931 and 915 gearsets are interchangeable - if this is fact, is there any advantage to assembling the 915 with stacks from both boxes?
keith
r gruppe #436
Old 02-26-2005, 08:58 AM
You'd have to check the gear ratios for that (assuming they're interchangable) and see if you like the combos.
As John pointed out, rings and pinions were run in together at the factory to ensure quiet operation and minimal wear. They're a matched pair and can't be separated.
Care to post some pics and info about your Carrera 3.0?
Old 02-26-2005, 09:50 AM
newb.
eimkeith's Avatar
Just got it - it's a project (not running, some assembly required).
Moving out of my 951 to fund the build.
keith
r gruppe #436
Old 02-26-2005, 07:10 PM
