Trans refill -- Is this normal?
Switching over to the Smurf oil and just wondering about this.
Is this a normal amount/type of metallic shavings ? It's maybe 10K since last drain. todd 86 coupe
I don't know about "normal", but I usually see more of a silvery paste than any identifiable metallic shavings...
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Last weekend when I changed out the swepco in my 915, it had a silver paste as well - about 15k miles worth.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Silver (or white) paste is an indication that water and oil have mixted. The water is usually condensation. It is normal.
Metal shavings of this magnitude means that you've (or the PO has) been "grinding the gears". Not serious, but do make sure your clutch is ALL the way in before shifting into the next gear.
Andras 1983 911SC The Chocolate Kiss 1998 Audi A6 Quattro (Family Car) 2002 Audi TT Roadster (Wifey's Car) 1992 Mazda Miata (Daughter's Car) 1991 Honda VFR750F Interceptor 1982 Honda VF750S Sabre |
Definitely normal.
Edward
993: retired Trackmeister, now daily driver heaven 911SC: resident Trackmeister-in-progress |
If you are really worried, Dow Corning Molykote M Gear oil additive is supposed to "heal" metal surfaces.
Thread link: 915 miracle juice
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
18K miles worth of fuzz.
John Adams 1980 ROW 911SC |
Registered abUser
Those all look a lot better than what I pulled out of my trans last month. No hint of problem while driving.... yet, shifts fine.
normal - also the actual shavings are much smaller than the Xmas trre effect you are seeing in the photo -- they are stuck together
- pull some off with tweezers, mix in a solvent and view under a lens - then you'll see the real size is much smaller.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
This is an ok drain plug (before and after cleaning by hand):
This is bad news (note dog tooth):
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 02-25-2005 at 06:16 PM.. |
Terry...what was that dime doing floating around in your tranny?
never mind
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 02-25-2005 at 06:54 PM.. |
19 years and 17k posts...
Mine looked just like yours, normal, I was told...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Registered abUser
It was definitely, as someone put it, the 'christmas tree' effect on the magnet. . . .
On another note, the Swepco seems to have caused a small but noticeably smoother operation. todd 86 coupe |
