strut install question
Ok, here's a dumb question...
Do the three bolts that screw in through the top of the strut tower actually thread into the body sheet metal and then into the strut? Or, just thread into the strut itself after passing through the tower? Thanks! Markus |
They pass through the body, and into a plate underneath that is not part of a body.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Do the bolts actually thread into the plate underneith the tower or just pass through before threading into the strut?
If the former, can I replace this plate separately? I have a crossthreading problem. Thanks, Markus |
The three bolts are for your alignment adjustment and connect the strut mounting plate to the car.
The bolts thread into the plate on the bottom side of the strut tower. The two parts actually sandwiches body sheet metal. The strut connects to the plate through 2 large rubber bushings and the large nut with large cup in the middle of the plate.You may be able to drill and tap to larger bolt to salvage the bottom plate. Hope this helps.Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Dan,
Is the plate on the bottom side of strut tower replaceable without getting into the bodywork (if sandwiched)? |
Yes, it is replaceable, but you can re-tap it for a slightly larger size, or may just be able to clean up the old buggered up thread with just a clean tap.
I think the part number for the strut mount is 911 341 018 00
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
