Who is John Galt?
Rondinone's Avatar
All hail the automatic heater
I just reconnected the automatic heater, and it is sweet. The PO stripped the connecting rod. I now have comfortable winter driving. Why do so many people rip these out?
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 02-27-2005, 05:40 PM
Send a message via AIM to cactusdtd
Hear, hear for the auto heater........mine works fine and maintains a near perfect temp ......now if i could only get the AC to work as well
Dan
'87 Targa
Old 02-27-2005, 06:57 PM
Noel's Avatar
I agree. I love my auto heat too.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 02-27-2005, 09:06 PM
Can you guys tell me what you mean by automatic heater.
I have an '83. I pull the red levers in the center to start the fans that force air through the exchangers and into the passanger compartment.
This is not what I would call automatic.
Old 02-27-2005, 09:12 PM
Hilbilly Deluxe
emcon5's Avatar
Some models came with a rube-goldberg contraption to pull the lever for you, based on the readings of a sensor between the sun visors.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-27-2005, 09:29 PM
Some came with a climate control instead of the two red levers, dash levers, etc.
'80 SC
ausdilecce's Avatar
I too love my auto heat ! .. Don't have a clue why sooo many people have problems with it..
My old 83 SC had manual heat ( two red levers ). Found I had to screw with em constantly...
Emcon5, can you post a pic of the sensor between the visors ? My sensor is a vented hole on the dash next to the heater/defrost controls ( actual sensor is in back of the ashtray )
1987 ROW Carrera Targa, SW chipped
1983 U.S.A. SC coupe ( bro has her now )
Old 02-27-2005, 11:00 PM
Mine are only the semi-automatic type, but I rarely turn the numbered dial thing. I just pull up the levers. Keeps you surprisingly warm on a cold day with the roof off.
-Steve
'87 Carrera Targa
Old 02-27-2005, 11:30 PM
Up to 85 the 85 has a "hanging sensor" between the visors in a rubber tube.
For 86 ( I believe) and later...the sensor is located in the dash and it draws-in air via a small fan, even.....( complicated Germans !!!)...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-28-2005, 06:53 AM
Used Up User
imcarthur's Avatar
The components of Autoheat for 1987. Slight error- there is only one heat echanger sensor. Go to link below for final.
Edit: See Components
'87 Carrera Cab
Old 02-28-2005, 07:17 AM
Ian,
Excellent work! Now to truly make it complete one would add the AC controls, blowers, and vents to the picture. Incidentally, my autoheat is perfect if i keep the AC thermo at the "III" position, the AC fan at the "II" position and then control the heat using the autoheat number dial (setting 3 for temps in the 40s; setting 4 for temps in the 30s)
Dan
'87 Targa
Old 02-28-2005, 07:26 AM
Used Up User
imcarthur's Avatar
Not enough room for all of those components too . . .
The companion diagram for Autoheat:
Edit: Image deleted - see page 2 of this thread
I am trying to develop a FAQ/troubleshooting thingie for Autoheat. Hence the pics.
Ian
'87 Carrera Cab
Old 02-28-2005, 07:39 AM
Hilbilly Deluxe
emcon5's Avatar
Not a very good picture, but this is it:
It it just a short rubber tube.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-28-2005, 07:45 AM
ausdilecce's Avatar
emcon5,
Thanks !.. Learn something new every day ... Looks like SCs autoheat is very different to post 86 autoheat..
imcarthur, Great pic. Couple of things tho.. The pic is for 1987 and newer 911s.. and
According to my owners manual, *if* the car has AC, the large center dash vent is for AC only ( and so NOT fresh air ), and there would be 'extra' AC vents under the dash. As I understand it, you control which vents supply AC by opening or closing the vents with the up/down knurled knobs.. ( one cannot close the extra footwell vents tho )
Great job explaining the levers tho
Old 02-28-2005, 12:32 PM
question on console heater switch. My 86 has a three spped fan switch, however, speeds one and two don't work. Any troubleshooting suggestions?
Thanks.
Tony G
2000 Boxster S
Old 02-28-2005, 12:44 PM
Former Options Trader !!!
okay call me a fool I have both that auto heat dial and the red levers. Just lucky?
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 02-28-2005, 01:12 PM
ausdilecce's Avatar
trader220,
You Fool
Post a pic please.. Do you know what the levers do ? How many numbers are there on the autohead dial ?
Old 02-28-2005, 01:27 PM
Used Up User
imcarthur's Avatar
Thanks. I'm working from memory (my car is in storage for winter) so I don't have one to test - and of course the manual is confusing.
How's this?
Ian
'87 Carrera Cab
Old 02-28-2005, 01:28 PM
Ian,
Actually there are two different sets of air sources under the dash in the foot well: one set is for Air conditioning (it is one source with a little diverter device that splits the air flow left and right - attached to the foot wall ) and another set located up under the dash that is a fresh/hot air source. Also the dash vent directly above the radio is air conditioned only. In further refining of your definitive guide perhaps you could use red for hot air, white for fresh air and blue for chilled/conditioned air. just a suggestion
Dan
'87 Targa
Old 02-28-2005, 01:42 PM
Used Up User
imcarthur's Avatar
Dan
I'm ignoring AC for this. It gets far too confusing when you include ac, fresh & heat to the diagrams - even though they are intertwined.
Here's where I've started it Link. Suggestions are very welcome.
Ian
'87 Carrera Cab
Old 02-28-2005, 01:50 PM
