valve guides
How hot should 911 cylinder heads be heated when pressing in new guides?
Old 03-03-2005, 05:36 AM
cold is fine. just mic all the guides that came out and be sure the new ones are the same size, or no more than 2/100ths mm larger. spray WD-40 down the bore and on the guide and press or drive then in. i use an airhammer, gentle on the trigger, and a guide driver with a fat flat washer on it to protect the top of the guide.
206 637 4071
Old 03-03-2005, 07:43 AM
