Question Fuchs 6 x 16 vs 7 x 16
I am putting my 7 x 16 fuchs up front and getting a pair of 8's for the rear. My question is on the 7's up front will the extra 1'' be equally split with 1/2'' going to the inside and 1/2'' to the outside?
I'm running 205/50 and the car is set at a euro height approx 24 1/2'' to the fender lip. I hoping I won't have any clearance issues with the 7's up front.
Old 03-04-2005, 08:44 AM
Monkey Wrench
Spede's Avatar
You will be fine with the 7s up front... it will fill out the well nicely.
Old 03-04-2005, 08:58 AM
The entire extra inch is on the outboard side....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-04-2005, 09:15 AM
If you run 225 tires on the 7's and your car is lowered you will need to roll the fender lips (I had to on my '89 when I did exactly that). My right side was a closer fit than the left.
www.competitiondata.com
Old 03-04-2005, 09:20 AM
I would say you SHOULD be OK with 7s and 205s. That is what I run, but I had to change out my old, tired, Boge inserts for some Bilstein HD inserts to stop the rubbing on sharp hits at speed. Now, it's good and I want to try and get to 225s next. More work to do first though.
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 03-04-2005, 11:11 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
To be safe before you learn the hard way and you cut your tires during hard cornering. Roll the fender lips!
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-06-2005, 10:53 PM
Depends a lot on the "specific" tire...regardless of quoted size. Similar size tires may be square or round shouldered, and have vastly different overall widths...
I'd like for us to all get in the habit of quoting the actual "tire" that seems to work ( or not)...and not just the "size" like 205 or 225.
Someday
Wil
Wil Ferch
Old 03-07-2005, 06:31 AM
Bill Verburg's Avatar
Like Will said the entire width of a 7 over a 6 is on the outside. See
here for additional details
You want to compare +36mm 6 w/ +23.3mm 7
Most cars will need some work done on the lips to accomodate this move.
Bill Verburg
Old 03-07-2005, 12:30 PM
Somatic Negative Optimist
Gunter's Avatar
Is that 205/50 a typo? Do you mean 205/55? I put 7's in front and 8's in the rear with 205/55 F and 225/50 R. In other words, I stayed with the standard tire sizes and it works/looks great.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-07-2005, 02:19 PM
RETIRED
Joe Bob's Avatar
964 wheels....stock 16 inchers...what's the spacer needs to fit an SC and Carrera? 1 inch up front and 2 in the rear right?
2012 ML350 3.0 Turbo Diesel
Old 03-07-2005, 02:23 PM
