CV joint boot clamps
My porsche dealer says my CV joints boots do not have a clamp on the little end. Is that true? Sorry for the dumb question, I am new to CV jont-ism!
Thanks!
Kelly Bell 72 MGB 75 911S 00 Volvo S70 |
That is correct. Clamps only on the outer (big) ends. Due to the centrifugal forces the outer (big) ends will carry the highest load. I still used a plastic zip tie for the inner (small) ends just to make sure - just don't overtighten so the boot can move a bit.
Regards, Guenter 73.5 911T, mod |
We'll I'll be horn swaggled. Thanks!
Somatic Negative Optimist
Put a zip tie on the small end, especially if the boots are older. Otherwise, the centrifugal force can send lumps of grease flying like it happened to a friend. You want the moly grease to stay inside the boot.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
Zip tie as in a nylon wire tie?
yes.
there is a group that believes in putting a small hollow tube (red spray can nozzle) under the boot at the little end.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Like what comes on a WD 40 can? Why?
Hmmmm. I have to agree. There is very little air in there to expand and contract. If pressure did build up, then so what? It wont break the boot...........
Supposedly lets air move in & out w/o pushing grease. I forget who thought the idea up. I tried it this time. Next time will probably go back to no tube. I don't see it as a big deal either way.
Not to mention how easy it is for a small bit of grease to clog the tube in a instant.
The boot kits I've always gotten have large and small clamps...
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
I bought the CV boot clamp 'crimper pliers', but cannot figure out how the h*ll they work,I have a mechanic pal who is also nonplussed.Has anyone had any success with them ?
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!. 1977 911S 2.7 to spend money on 2006 Tundra for acting grownup |
You need to have the correct pliers for the particular clamp you are using. The clamps that come in the boot/repair box that Pelican sells, for example, are Oetiker "ear-type" clamps. The extra clamps that Pelican sells by themselves are of a different type (don't know what they are called). I had purchased the wrong pliers, and there was no way I could use them to crimp the clamp's ears. Went to Auto Barn, bought a good, heavy duty ear-type clamp, and it was a no brainer. Never did use the separate clamps from PP as I couldnt figure out how to secure them. I did use a clamp on both ends, since it is in the boot repair kit. No problems so far, and it's been a while since I changed the first one.
On the same topic, I tried very hard to find a supplier for th3e Oetiker clamps with no success. I tried all the usual places, including McMaster-Carr. The size of these are 74mm x 9mm-large end 35mmx 7mm small-end Anyone know where I could pick up a few of these? I know that they are also used on gas station pumps if that helps.
Mike 1986 930 Last edited by mike f; 03-09-2005 at 12:50 PM.. |
Don't mean to hijack the thread but when I had my transmission rebuilt, they put nylon zip ties on the big ends with nothing on the small end. I looked at the cv joints recently and noticed that the boots have pulled off of the big end, meaning the zip ties didn't hold. I would like to put on the metal Oetiker clamps, but does that mean I have to take apart the joint, as it doesn't look those type of clamps have an opening. Did they do something wrong such that the boots didn't stay on the end?
Tim 1983 930 w/ goodies |
The Oetiker clamps have "grooves" on one end and a punched in "tab" that catches in the groove on the other, mating end. You just need to pull the "tabbed" end over the "grooved" end as far as possible. Then with the correct crimping pliers the ear will squeeze tightly and secure the clamp as the tab pulls the groove towards it. In this pic, it's the one on the top left.
![]() And here's a picture of the correct pliers.
Mike 1986 930 Last edited by mike f; 03-09-2005 at 08:29 PM.. |
Regards, Guenter 73.5 911T, mod Last edited by buster73; 03-10-2005 at 09:23 AM.. |
Thanks Guenter for the reply. That sounds like what exactly happened. I would have thought my shop knew better. I'll pitch them and put on the right clamps.
I would rather be driving
HMM I have used large zip-ties on the large ends of my CV boots. No leaking, no stretching, still as tight as teh day I installed them 3 years ago. multiple track days too.
YMMV
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
