Another "my first engine drop" thread!
Hi all,
Dropped my first 911 engine last night and feeling pretty good! On the to-do list is: oil cooler seals throw out bearing new clutch disk (maybe?) oil thermostat seal oil return tubes valve adjust power coat fan and fan surround general cleaning Anything else I should take a look at while I'm this far apart? I have Wayne's 101 book and it has been a great help with the project so far. I've taken off the AC (not working) in the process and will not be putting it back on. Same goes for the smog pump. Sorry for the bad pics.....can't expect much from a cereal box digital camera! ![]()
Phil 1978 911 SC |
I'm curious...why did you decide to separate the engine and tranny? Don't most people suggest dropping them as a unit?
1984 Targa |
This has always been a long standing debate. After having been through the process more than a few times, it is much quicker and easier to just drop the engine. The key to this is understanding how the fork is engaged to the throwout bearing. Disengaging and reengaging is a little tricky and it's much easier to observe and understand once the engine and tranny are on the ground together. So for the first attempt, best to drop them as a unit. Once you learn to disengage the the engine from the tranny, leaving the transmission in place you will save a ton of labor and time. Its a real PITA to disengage the fore wires and cables, to undo the transaxle and to say nothing about the reinstallation. You can read stories of transaxles comming undone if not reinstalled correctly, it's really hard to reinstall the bolts holding the transmission and very easy to crossthread them.
I went back and forth on if I should pull the transmission out with the engine or not. Like Ed mentioned, there are people on both sides of the issue. I did a lot of reading here on Pelican and just decided to take the engine. It really came out smoothly...we'll see how much it takes to get the clutch fork back in my first time!
I got an ATV jack which really made the whole thing stable which was good because I was by myself.
Phil 1978 911 SC |
Is that a battery under the left rear tire???? Very novel jack stand.....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Congratulations, but you're missing a pic -- we need to see your self-portrait, with you standing in the engine bay!
It's kind of a cult-tradition thing, here at Pelican.....Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Congrats! I think you get extra points for doing it in Alaska in the Winter. Throw up a pic or 2 of that beautiful colored SC in front of a glacier or a mountain or something.
...sick with gearheadia |
Hehe, no not a battery. Looks like one though I guess.....it's my wheel ramp with a sticker on the back. Quote:
Phil 1978 911 SC |
Sorry 78sc, it did look like a battery. Looks like you're doing a great job. If you did all that w/o a helper, my hat is off to you....
Another question also. How would I tell if the pressure plate on the clutch is worn out/weak and needs to be replaced? Is there a spring test or something that I clutch shop would do? Enjoy! Phil
Phil 1978 911 SC |
ELVIS 84 CAB -SOLD |
Semper drive!
Seriously, though. Congrats!!!! Nice job. Have to add myself to the list of people impressed you did this during Winter in Alaska. I spent a February in Fairbanks a few years ago and there is no way I'd want to do this in my garage at those temps.!!! Good on ya! Now quickly...get yourself a few gallons of hot chocolate and thow out for a while!!! Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Did you make any mods to the motorcycle jack that you used, or did you use any thing between the jack and engine?
That IS some beautiful country you live in. Around here you cant see the mountains for the trees
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Does anyone know about clutch pressure plates though? How would I tell if mine needs to be replaced? It was working ok before I pulled the engine, but if It's near the end of its life, I would get a new one. Oh.....new camera is on the list, but if I have to choose between a camera or more 911 parts? Hmmmmm.... ![]() Thanks, Phil
Phil 1978 911 SC |
Wow, beautiful country up there!
To my knowledge, if there is any wear or obvious scoring on the pressure plate fingers from the throwout bearing, then you need to replace pressure plate. Also, if you set the pressure plate on a surface and spin it on its throwout bearing, that will give you a good indiction of its condition. When you spin it, it should be very smooth. |
