H.G.P.'s Avatar
Confusion over cam timing tables, am I mixed up?
Stamped on each of my camshafts are the "dot" stamped on the top (when at TDC), and in this same orientation on the bottom of each is stamped "05"
I'm not sure if I did the correct dial reading, as I used the reading page 207 in Waynes book for 69 911E, but in the Haynes there is a refererence to a 901/05 as "engine" for dial gauge reading.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 03-10-2005, 06:55 PM
camgrinder's Avatar
The 05 cam is the E profile.
Should be set at 3.0 to 3.3 mm.
John Dougherty
Dougherty Racing Cams
Old 03-10-2005, 07:10 PM
H.G.P.'s Avatar
"camgrinder The 05 cam is the E profile.
Should be set at 3.0 to 3.3 mm. "
Whew...thanks!!
1969 911 E Coupe
Old 03-10-2005, 07:22 PM
