CV hex nut stripped--HELP
One of the hex nuts that attaches the axle to the back of the rear wheel is stripped. What are the tricks I can do to get this out? Thx
1980 911SC Targa 3.6L
Old 03-20-2005, 01:51 PM
911mot's Avatar
Hammer in a slightly larger torx socket then use an impact driver to crack it free
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 03-20-2005, 01:57 PM
randywebb's Avatar
CV joints are held with cap screws - or are you talking about something else (?) Is this a Carrera?
so expect it to act that way not like a nut if its the CV joint screw
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-20-2005, 02:37 PM
I used a dremel and cut a slot in the head. Then used a screwdriver held perpendicular to the bolt. Make sure you use the 12 point drivers for these. 6 point or allens dont fit.
Kevin
'79 Coupe
Old 03-20-2005, 02:57 PM
pwd72s's Avatar
These can be a handy addition to a tool box.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00952166000
This is for an SC. The hex bolt I'm talking about is behind the wheel (not next to the transmission) but right behind the wheel that attaches the axle to the hub. Sorry if my terms are incorrect I know that makes it difficult to help. I removed 6 or so of them and it they appear to be 6 sided hex bolts. The others came out pretty easily. I'll try the oversized torx head method first. Then try cutting a slot with my dremel.
Old 03-20-2005, 04:01 PM
randywebb's Avatar
a hex bolt has a 6 sided cap - like you'd grab with a wrench
an Allen head bolt or cap screw has an INTERNAL 6 sided thing - that's what the torx idea is for
a nut is like a big thick washer with 6 sides on it - it threads onto a bolt and has internal female threads - for them you can use a nut cracker to break them into 2 pieces.
Old 03-20-2005, 04:13 PM
makaio's Avatar
Small pipe wrench worked for me on my stripped cv bolts.
Old 03-20-2005, 04:34 PM
Randy--you're right--its a allen head bolt and I finally got it off. I cleaned out the inside of the internal 6 sides--there was quite a bit of grease and dirt in there. Probably why the allen head socket was not gripping the inside. Anyway, after doing this and tapping the back of the socket with a rubber mallet and slowly applying pressure it came out and I could pull the axle and CV away from the wheel hub. Thanks for the help all,
Old 03-20-2005, 05:31 PM
Virginia Rocks!
VaSteve's Avatar
I just got a set of those. I used them to remove the nuts holding on my cataletic converter. They are the bomb-diggity-om! (that's good). They really made quick work of the job.
I'm keeping them nearby to ensure I never need them again.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 03-20-2005, 05:35 PM
pwd72s's Avatar
Isn't that the truth? One law of car guy karma...if you have a tool or a spare part nearby, it won't be needed...
Old 03-20-2005, 05:39 PM
randywebb's Avatar
Congrats Jon
Be SURE to do a search from more info on CV joint maintenance before finishing.
Old 03-20-2005, 05:45 PM
I will Randy--now its on to my Trailing arm that has become my next target. I created a new post for that one. thanks again.
Old 03-20-2005, 05:57 PM
